On Mon, Apr 4, 2016 at 8:01 PM, Even Rouault <even.rouault@anonymised.com>
wrote:
2.0 can be used, but the key is to use the same swig version (at least
major
number) to generate the .jar and the native .cpp files.
Hi Even,
thanks for pitching in, we can really use your opinion.
Unlike CGI based servers we have a higher bar for production use, as
a single segfault will take down the entire server (even with watchdogs
restarting
it, that will mean minutes with no service at all).
Under our normal operation conditions the process will stay up for
days/weeks/months, meaning we're also quite sensible to any form of memory
leak, and of
course it means for all that time GDAL will be under multithreaded load for
all that time.
So far recent releases of GDAL 1.x have worked well, but if I understand
correctly,
GDAL 2.0 has been a significant refactor. Do you know of any other project
that
has already used GDAL 2.x in anger under conditions similar to GeoServer
ones?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
