[Geoserver-devel] GeoServer Importer maximum running jobs
Dear all,
I’m using the GeoServer importer and I noticed I can start as many sessions I want without receiving an error. Some of the sessions will simply go back to a “ready” state without having effect.
After a little digging I foung this class: https://github.com/geoserver/geoserver/blob/master/src/extension/importer/core/src/main/java/org/geoserver/importer/job/JobQueue.java
If I understand it correctly, the queue it’s not actually queueing anything, it’s a direct handoff, so the jobs will be executed immediatly until the thread pool reaches its maximum size.
And since the maximum pool size is Integer.MAX_VALUE I guess I should not start too many sessions at once.
If my findings are correct I’m going to open a JIRA to make the maximum number of concurrent jobs configurable.
What do you think?
Thank you
Lorenzo Pini
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Lorenzo Pini
Software Engineer
Via di Montramito 3/A
Hi Lorenzo,
yep, sounds like a good idea
On Fri, Feb 16, 2018 at 4:37 PM, Lorenzo Pini <lorenzo.pini@anonymised.com> wrote:
Dear all,
What do you think?
Thank you
Lorenzo Pini
Lorenzo Pini
Software Engineer
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
