[Geoserver-devel] GeoServer Importer possible issues
Dear all,
before opening JIRA issues for this I would like to hear from you if someone has some idea on what is going on, maybe it is just my mistake.
Today, while testing the GeoServer Importer with GeoServer 2.7.x (both the war and the plugin downloaded from geoserver.org) I experienced the following two issues:
  1. The strangest one… in order to let the Importer working correctly I had to put manually on GeoServer the following jar
commons-vfs2-2.0.jar
Otherwise I get a
java.lang.ClassNotFoundException: org.apache.commons.vfs2.FileSelector
  1. Trying to follow the steps here
http://docs.geoserver.org/latest/en/user/extensions/importer/rest_examples.html
in order to download a CSV file, I get a state: NO_FORMAT from the Importer.
Taking a look at the logs, it tries to parse it as a JSONFeatureFormat instead of a CSV one
Any idea?
Many thanks,
Alessio Fabiani.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Sep 21, 2015 at 4:32 PM, Alessio Fabiani <
alessio.fabiani@anonymised.com> wrote:
Dear all,
1. The strangest one... in order to let the Importer working correctly I
Otherwise I get a
Commons-vfs got upgraded recently, evidently I've failed to also update the
packaging for the extension. You're the first to notice. Open a ticket.
2. Trying to follow the steps here
Importer.
Any idea?
No, not sure why that is happening.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
