[Geoserver-devel] Geoserver Installer
I have successfully run the geoserver installation program NSIS, I have to change the installation script a bit.. Here are my changes:
It required the following files which was missing, should these files be added or are they there that I need to copy over?? Please advise,
    * #File /r documents
    * #File /a README.txt
    * #File /a RUNNING.txt
    * #File /r server
Kind Regards
Clint Lewis
Ok, some of these files still need to be copied over form the 1.3.x branch.
README.txt, and RUNNING.txt need to do in "release", anaded to release/bin.xml
server needs to be replaced with webapp/geoserver
For documents, you need to add a fileSet to release/bin.xml, and release/doc.xml to pick up everything in release/docs.
-Justin
Clint Lewis wrote:
   * #File /r server
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Those files are needed, so just copy them over. I also noticed that they were missing and have it changed here on the branch I am working on. I just changed the ant script to copy those files over.
Brent Owens
(The Open Planning Project)
Clint Lewis wrote:
   * #File /r server
