[Geoserver-devel] GeoServer Jira on Atlassian cloud created
the process with Atlassian has been quick so far, and we have our own instance of Jira running here:
https://geoserver.atlassian.net/projects/GEOS
For the moment I’ve turned off self sign in to make sure the instance is left pristine (if we want to migrate
issues, we don’t want another GEOS-1 around to conflict with the one we would like to import), if you are
a PSC member contact me to get an admin account.
So… what are our next steps?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Next step is to contact astrodog and see how the idea of transferring via REST API is working out (he was putting together a quote for OGC).
Should also check in with SAC - as they are exploring providing hosting for us. What capabilities are offered by the cloud hosting? Can it call out to osgeo LDAP to authenticate users … or is this a new user list.
On 6 March 2015 at 00:19, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Jody Garnett
On Fri, Mar 6, 2015 at 6:27 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
to osgeo LDAP to authenticate users ... or is this a new user list.
As far as I can see it is a new user list, not sure which LDAP connection
options are there.
But to be honest, having the creation of accounts far from Jira did not
really work well for our user base (the "create users in Xircles" thing put
off many)
Ing. Andrea Aime
@geowolf
Technical Lead
-1 about using LDAP
I might wrong but it should also require self-hosting.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Mar 6, 2015 at 6:35 PM, Andrea Aime
options are there.
off many)
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
sponsored
all
to
Agreed, we can ask users to set up a new account with Jira.
Just to be clear Andrea - you have asked on behalf of the GeoServer project about cloud hosting JIRA.
Do I need to go back and ask on behalf of GeoTools? Or should I ask on behalf of OSGeo.
My impression was we preferred the option of cloud hosting if it was available.
If so should we update the open tac ticket with SAC?
On 6 March 2015 at 09:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
As far as I can see it is a new user list, not sure which LDAP connection options are there.
But to be honest, having the creation of accounts far from Jira did not really work well for our user base (the “create users in Xircles” thing put off many)
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Mar 6, 2015 at 7:35 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
behalf of OSGeo.
I also got permission for GeoTools (separate instance), I just did not
start up the instance yet
cause I wanted to see how it worked, but I can do that before leaving for
SF, or during the weekend.
Each instance can host multiple projects, so one would be sufficient, but
having geotools
hosted inside geoserver.atlassian.net would be weird at least.
Theoretically one could ask for a osgeo.atlassian.net... I did not think
about it, and I guess
I would be the wrong person to ask (the one that asks becomes the contact
point), but we
can hear atlassian about that option if you want?
Ing. Andrea Aime
@geowolf
Technical Lead
OsGeo would be best, sorry for the confusion.
I also got permission for GeoTools (separate instance), I just did not start up the instance yet
cause I wanted to see how it worked, but I can do that before leaving for SF, or during the weekend.
Each instance can host multiple projects, so one would be sufficient, but having geotools
Theoretically one could ask for a osgeo.atlassian.net… I did not think about it, and I guess
I would be the wrong person to ask (the one that asks becomes the contact point), but we
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Mar 6, 2015 at 7:56 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Maybe you can ask someone as OSGeo to forward that request then?
Ing. Andrea Aime
@geowolf
Technical Lead
As officer for GeoServer you can step forward, or I can as GeoTools officer.
On 6 March 2015 at 11:05, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Okay I am going to go make a proposal on the SAC email list for osgeo.atlassian.net. The SAC email list is where the proposal to port issues via REST API is being sorted out (just asked on IRC).
I expect that as project leads we would be the main point of contact Andrea. Personally I would set up PSC members with admin access and consider it done.
Jody Garnett
Jody Garnett
On Fri, Mar 6, 2015 at 7:56 PM, Jody Garnett <jody.garnett@anonymised.com403…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
I believe we should ask the board before using the Osgeo name on a Web site.
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Yep, that seems the way to go, thank you.
Agreed
