Hey Artie, just start sending these to geoserver-devel, instead of just
me, ok? The list is to talk exactly about stuff like this, and if it
just goes to me it may get lost in my inbox.
Chris
Quoting Artie Konin <a-thor@anonymised.com>:
Greetings, Chris,
Friday, May 27, 2005, 1:58:18 PM, you wrote:
> If you just comment out the line that starts the log4jformater then
it
> should pick up your jvm levels, in the logging.properties file.
You can
> specify package levels and whatnot there. Perhaps we should have a
config
> option to completely turn f the log4j formatter logging. The
thought
> behind it was to allow users to easily configure through the web
app, but
> it is at the price of more fine grained control for programmers.
Ok, I was experimenting with different variants for a while, so
that's why I didn't responded earlier The way you suggested is
probably the simpliest one, and it works. Hovewer, the output looks
awfully: that two lines per message, full stack traces in most
harmless situations and so on. Also as there is one
java.util.loggging.LogManager instance per JVM, changing
configuration
file in the JRE could affect other applications running on the same
container (as well as container itself) badly. In fact, I
inadvertently
blanked the whole tomcat log output two or three times trying to
configure the loggers in the way I wanted (and I should admit I still
wasn't able to figure how to use my custom Formatter with this
logging
system). Not very satisfactory results indeed
> I do sort of want to use commons logging or some such, I'm not in
love
> with java logging...
Nether do I I've tried some variants of using another logging
packages with GeoServer (not many, though - in fact there were only
two of them - Log4j and Jakarta Commons Logging aka JCL) and here are
the results:
1) JCL by itself is probably not a sufficient replacement of JDK
logging, as it is merely a wrapper over another logging packages.
including JDK logging itself. Of course, that is if one doesn't want
to use bundled SimpleLog class - in latter case JCL can work as
standalone logging implementation, but capabilities of SimpleLog are
quite limited. So JCL should be paired with another (richier) logging
implementation (and, probably, not that from Sun
2) First I thought that as JCL is a wrapper it should provide
seamless
switching from one underlying implementation to another without
rewriting the code. But it turned out that this is not the case, at
least with GeoServer. The problem is that
org.apache.commons.logging.Log interface which is implemented by all
implementation wrapper classes (as well as by their own SimpleLog
class) exposes very restricted set of methods. There are six logger
methods: trace(), debug(), info(), warn(), error(), fatal(), each in
two forms (one and two arguments, first is the message second is
Throwable) and six corresponding code guards: isTraceEnabled(),
isDebugEnabled(), ... etc. That's all So your logging code will be
implementation-independent only if it is all about publishing log
messages. If you want, for example, obtain logging level of specific
logger, you will need to cast it to the implementation-specific
wrapper class (org.apache.commons.logging.impl.Log4JLogger,
org.apache.commons.logging.impl.Jdk14Logger etc.), get underlying
logger with getLogger() method and then use its native methods to
obtain the level. At this point you are stuck with specific
implementation and wouldn't be able to change it without modifying
the
code :\ And this is exactly GeoServer situation: while 99% of its
logging-related code could be switched to JCL with primitive search
and replace operations, the remaining 1% is a tough spot It will
be implementation-dependent in any case, whether we use JCL or
working
directly with that implementation. This makes the usefulness of JCL
quite questionable. (Though, I personally use JCL in my client and
totally happy with its SimpleLog
3) The only "real" third-party logging package I tried is Jakarta
Log4j. It seems that it is quite common choice of Java developers.
It key benefits are:
a) GeoServer already has log4j jar in its /lib (though I wonder where
it is used?) - no need to add another bunch of jars, as with Avalon
Logkit etc.
b) It is excitingly easy to configure comparing to JDK logging. In
most cases a single file log4j.properties placed in /classes
directory
will do the job, without any programmatic initialization.
c) One of the most important things is that log4j can (and should) be
configured at webapp level (that's really great, no that nasty
interference and external configuration files as with Sun's
logging).
d) It is seamlessly integrates with JCL. In fact, it is possible to
omit any explicit JCL configuration at all with log4j. I just
placed
commons-logging.jar in /lib together with log4j.jar and was able to
use JCL logging based on log4j configuration I supplied.
e) There is a very convenient .log4j.threshold parameter in
configuration file which sets the global logging level, which is
applied regardless of individual loggers settings. So it is only a
matter of changing single line in .properties file to apply
"global"
logging level. Of course, threshold may be also set
programmatically
(though right now I cannot say how to do this exactly, there are
methods setThreshold() in LoggerRepository interface and
implementing Hierarchy class, which seems may be retrieved with
Logger.getLoggerRepository() method).
f) All later versions of Log4j have similar syntax to that of JDK
logging, for example code for obtaining the logger is exactly the
same:
private static final Logger LOGGER =
Logger.getLogger("org.vfny.geoserver.global");
The only difference that Logger class is org.apache.log4j.Logger
and
not java.util.logging.Logger
g) Log4j's Logger has that nice convenient level-tailored code
guards:
isDebugEnabled(), isErrorEnabled() etc. Writing
if (log.isDebugEnabled()) {...}
to me is much much simplier than
if (LOGGER.isLoggable(Level.FINE)) {...}
Latter even seems clumsier and often make a difference between
guarded and unguarded logging statement
Well, there are some more of them, but they are less significant, so
now disadvantages that I see:
a) The code needs to be adopted. That itself is bad enough
b) Logging levels has different names so it will need some time to
get
used to them (these are DEBUG, INFO, WARN, ERROR, FATAL).
Moreover,
they are not mapped too well with JDK's levels.
c) There are only five different log levels in Log4j. The result is
that
if we use usual intuitive JDK->log4j log level mapping:
SEVERE - ERROR
WARNING - WARN
INFO - INFO
CONFIG - INFO
FINE - DEBUG
FINER - DEBUG
FINEST - DEBUG
we end up with three different debugging levels of
java.util.logging mapped to a single DEBUG log4j level. That is
definitely not good. The "recommended" solution here is to
subclass org.apache.log4j.Logger and to define custom levels
there.
But in real life, using of such a custom levels is very
inconvenient :\ For my testing, I avoided this problem by patching
log4j sources - somewhat ugly, but it works
d) The complete log4j manual is commercial. But it is as well
possible to learn almost everything about the framework using
only short manual, api docs and source code.
e) Well, in any case, log4j isn't shipped with JDK and therefore not
such ubiquitous (not a real problem, but for someone this may
prove
to be critical
4) So, basing on the all above there are four possible variants I
see:
I) Do nothing In the end, if JDK logging was good for all
GeoServer developers for years, why break the habit and switch
to
another implementation
II) Switch to JCL with log4j as underlying implementation. In this
case modifying existing code would be somewhat harder, but the
result is somewhat more "universal".
III) Switch to log4j directly. Less pain (though mostly in
automated search/replace part of the work) and might be slightly
faster. Why introduce another abstraction layer (JCL) if part of
the code will work with log4j directly?
IV) Investigate some more logging frameworks (like Avalon Logkit)
and possibly choose one of those
Personally I chose the second variant for my tests as it seems to be
the most complex of those And, surprisingly, now I have an
instance
of GeoServer here up and running which uses exactly that logging
engine, though this was achieved not without a number of ugly hacks.
Here is a piece of tomcat log (long lines stripped):
3422 [TRACE] org.vfny.geoserver.global - FeatureType
t_koos_shp:::t_koos_shp looking up :t_koos_shp
3422 [TRACE] org.vfny.geoserver.global - in string url
3422 [TRACE] org.vfny.geoserver.global - t_koos_shp:::t_koos_shp
datastore found :DataStoreConfig[namespace=tambov, enabled=true, ...
4172 [DEBUG] org.geotools.data.arcsde -
com.esri.sde.sdk.client.SeConnection is in place.
4328 [DEBUG] org.geotools.data.arcsde -
com.esri.sde.sdk.pe.PeCoordinateSystem is in place.
4516 [WARN ] org.geotools.data.mysql.MySQLDataStoreFactory - Failed
on : dbtype
4516 [DEBUG] org.geotools.data.mysql.MySQLDataStoreFactory -
{namespace=http://www.tambov.ru/geoserver, ....
4610 [WARN ] org.geotools.data - Could not aquire Vector Product
Format Library data store
implementation.:java.io.FileNotFoundException: ...
java.io.FileNotFoundException: Could not find file:
C:\tomcat\webapps\geoserver\data\featureTypes\t_koos_shp\t_koos_shp.shp\lht
at
org.geotools.data.vpf.file.VPFFileStore.findFile(VPFFileStore.java:178)
at
org.geotools.data.vpf.file.VPFFileStore.getSchema(VPFFileStore.java:88)
at
org.geotools.data.vpf.file.VPFFileFactory.getFile(VPFFileFactory.java:134)
at org.geotools.data.vpf.VPFLibrary.<init>(VPFLibrary.java:167)
at
org.geotools.data.vpf.VPFDataStoreFactory.create(VPFDataStoreFactory.java:122)
Note that stack trace. It seems that Log4JFormatter currently simply
ignores any throwables passed to it, so in normal GeoServer log this
trace is absent. Of course, I could do this as well in the much the
same way, but I believe that it is better change logger call in
related geotools code section. After all, if you don't want to see
the
trace, then you don't pass it to the logger, and if you pass the
throwable, then you want to see it, right?
Now what I have done in order to make the things working:
1. Wrote simple PHP script that is traversing through GeoServer
source tree
and makes replacements that could be done more or less safely in
such way. It shouldn't be too hard to write its Java analog (I
simply was in haste, and writing such things in PHP or other
scripting language is usually much faster). Mostly that is changes
of import statements, log instantiation, logger calls and
codeguards.
2. Hack #1. Changed sources of log4j to add sixth log level - TRACE.
As a positive moment now JCL and log4j levels are mapped
one-to-one
:) As negative - it will be somewhat harder to upgrade to a new
version, though it taken only a few minutes - not too much.
BTW, in this case JCL can shield the code from being overrun by
"non-standard" log4j calls Later on both log4j and commons
logging can be replaced with their standard variants and the code
will not be broken (I hope).
3. Hack #2. Correspondingly "fixed" commons logging, so their
Log4JLogger wrapper class now knows about that extra level.
4. Hack #3. Changed Log4JFormatter class. Added a new handler which
redirects all geotools log messages to corresponding JCL loggers.
This is perhaps the most sloppy code, but it allows to control
geotools output from the same config file as geoserver's one.
Anyway it can be accounted for later, if needed.
I believe that something similar can be done for "pure" log4j
installation. What is the most valuable - now I (at last) have all
logging, including logger levels and output fomatting, configured in
a single configuration file - log4j.properties, which gives me
almost
absolute control over the process (well, in fact, I'd change log4j a
little bit more, as it seems to not allow specifiyng appender's
properties in config file, the things such as output encoding should
be
still configured programmatically - but that's only if there will be
some use of it, don't want to do fool's work
Ok, it is now up to you and other GeoServer developers to decide
whether and when to change the logging subsystem. I just made sure
it is
practically possible and even not too hard to accomplish
Cool. This is actually annoying, hearing the log4j is in fact better.
We were originally log4j - the reason we have the log4j formatter is
becuase RobH liked how it out put things better. The java logging was
kind of imposed on us, since GeoTools switched, and we didn't have any
real good reasons not to switch. I think if we switched back it might
make sense to use the commons logging, so we could pick up the java
logging stuff from geotools. Oh yeah, we should get rid of the log4j
jar, it's there because some libraries that we used to use make use of
it. But we don't really support them any more (z39.50 stuff).
The other capability I'd like to have if/when we switch logging is to
have it write to a database. Particularly access information, as
admins would be interested in such things. I'd like logging that is
more geared to users, the types of things they want to see, not just
the developers debug statements.
WBR,
Artie
This mail sent through IMP: https://webmail.limegroup.com/
