[Geoserver-devel] geoserver-master failures
Hi All,
It looks like some of the recent EPSG lookup changes in geotools are causing test failure(s) in geoserver:
Failed tests:   testReprojectLayerGroup(org.geoserver.catalog.CatalogIntegrationTest): expected null, but was:<4326>
  testSRSConverter(org.geoserver.config.util.XStreamPersisterTest)
Can we just change this test to expect EPSG:4326 now?
Torben
I think Andrea just merged a fix on GeoServer master.
Kind regards,
Ben.
On 22/11/16 08:06, Torben Barsballe wrote:
Hi All,
Failed tests:
Torben
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Yep… there were two parallel pull requests for the EPSG lookup speedup but only the gt one got merged… when I noticed it was already too late. Hopefully the build will go back to normal, if not consider reverting.
Kind regards,
Ben.
Hi All,
Failed tests:
Torben
Geoserver-devel@anonymised.comsourceforge.net
Director
Transient Software Limited <http://transient.nz/>
New Zealand
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.com66…sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Build is passing again, so everything looks good.
Thanks
On Mon, Nov 21, 2016 at 11:43 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Kind regards,
Ben.
Hi All,
Failed tests:
Torben
Geoserver-devel@anonymised.comrge.net
Director
New Zealand
GeoTools-Devel@anonymised.comge.net
