it seems that the geoserver nightly build was failing because the geofence
project was not performing an "mvn deploy", so some deps could not be
satisfied. I edited the geofence jenkins configuration to fix this.
I also fixed an issue in the communityModule pom file concening the geofence
module. Once the snapshots are reloaded, the build should complete
successfully.
In order to put the geofence war file in the dist/ directory, the script in
the geofence build includes these lines:
dist=${WWW}/geofence/$ver
cp gui/web/target/geofence.war $dist/geofence-$ver-$datestamp-war.zip
The cp is failing because the geofence dist directory does not exist, and
needs to be created.
I commented out these lines in order to allow the job to finish successfully,
and will put them back once the directory is created.
Emanuele
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
On Thu, Oct 16, 2014 at 8:29 AM, Emanuele Tajariol <etj@anonymised.com>
wrote:
geofence
successfully.
in
successfully,
Directory created, and chowned to jenkins user so should be good to go.
Emanuele
Technical Lead
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless <http://boundlessgeo.com/>
jdeolive@anonymised.com
@boundlessgeo <http://twitter.com/boundlessgeo/>
Thanks Justin!
GeoFence and related community module have been built and deployed properly in
latest run.
Emanuele
wrote:
> Hi all,
> geofence project was not performing an "mvn deploy", so some deps could
> not be satisfied. I edited the geofence jenkins configuration to fix
> this. I also fixed an issue in the communityModule pom file concening
> the geofence
> successfully.
> in
> successfully,
> Cheers,
> Emanuele
> GeoServer Professional Services from the experts! Visit
> Technical Lead
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> ----- Comprehensive Server Monitoring with Site24x7.
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Technical Lead
