Attending:
Jody
Brett Walker
Alessio Fabiani
Andrea Aime
Niels Charlier
Jukka Rahkonen
Agenda
- Importer pull request status
- Catalog service graduation
- Bug fixing
Actions:
- AA: Sanity check on Importer API (are changes needed to add additional formats)
Review of importer code, some hiccups that can be fixed later, Andrea indicate it is close to extension status (given previous QA in OpenGeo suite).
TODO:
- BLOCKER: headers ← need justin? … or any OpenGeo staff
- FIX: documentation? opengeo has UI docs, but nothing for REST, links to GeoExplorer etc…
Q: how far until RC?
A: 13 days … so it is going to be close!
Q: GeoSolutions Importer?
A: Had less functionality, but covers a few gaps (inner tiling and overviews, directory of GeoTIFFS). So expect a second pull request from Andrea with a merge (but after 2.5.0 since it only adds functionality).
Q: Will the above need API change?
A: Should not require many modifications … so expect it can be added to stable. May want a sanity check with Justin.
Many tickets, only a few bits of trouble.
- NPE following tutorial (tutorial fixed, code still vulnerable)
- http://jira.codehaus.org/issues/?jql=project%20=%20GEOS%20AND%20status%20=%20Open%20AND%20text%20~%20csw
- in general it is a bit fragile (layer rename, restart, etc…)
- recommend UI or REST API or respect the Reload button
Q: Is the Reload button realisitic for RC?
Q: Priority issues for graduation?
A: the following:
- BLOCKER: NPE - put a placeholder file in that results in an empty catalog?
- BLOCKER: Change/edit the mapping file without restart GeoServer (Reload button is the low bar)
Suggestions:
- prefix name into the mapped metadata (ie topp in topp:states)
Bug fixing
Bug fix spinrt:
- Closed 30+ tickets (around 10-15 actual fixes)
Q: Freeze? Actually everyone is adding features still … in order to make the release more exciting
Idea: Release candidate testing party?
- Priorities: Verifiy open bugs
- WFS-T over 3 MB? 9 years old, need set up test to verify
- test docs? CSS tutorial and CSS cookbook
