[Geoserver-devel] GeoServer Meeting 2017-06-27
On 28/06/17 04:34, Jody Garnett wrote:
App-schema online build fails every day and sends mails to Andrea directly
and to “geoserver-devel@anonymised.com”.
From: https://build.geoserver.org/job/geoserver-master-app-schema-online/829/consoleText
/tmp/jenkins8083760168206680279.sh: line 13: psql: command not found
It looks like psql is used in the Jenkins script to set up the postgis test database.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
From: https://build.geoserver.org/job/geoserver-master-app-schema-online/829/consoleText /tmp/jenkins8083760168206680279.sh: line 13: psql: command not found
Jody and Nick,
fixing this could be as simple as installing psql on build.geoserver.org. For Debian and Ubuntu, this can be achieved by installing the postgresql-client metapackage.
Kind regards,
Director
New Zealand
Hi Ben,
I’ve been working with Nick on this today, and the postgis and oracle online tests on build.geoserver.org are now passing.
See:
https://build.geoserver.org/job/geotools-master-online-postgis/308/
https://build.geoserver.org/job/geotools-master-online-oracle/313/
Torben
On Fri, Jun 30, 2017 at 5:52 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
and to “geoserver-devel@anonymised.comorge.net.off”.
Jody and Nick,
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Thanks, Torben and Nick. Much appreciated!
How many more builds need work? How close are we to retiring ares?
Kind regards,
Ben.
On 29/07/17 11:40, Torben Barsballe wrote:
Hi Ben,
I've been working with Nick on this today, and the postgis and oracle
See:
Torben
directly
test database.
Jody and Nick,
Kind regards,
Director
New Zealand
Check out the vibrant tech community on one of the world's most
Director
New Zealand
Remaining failing builds:
Some geotools builds fail on documentation, likely due to a different (newer?) version of sphinx. This is probably something that should be fixed in the docs themselves rather than the build server.
Some geofence builds are failinggeoscript-groovy is failing
geoserver-master-app-schema-online is failing.
Everything else looks good.
I’d say we are pretty close.
Torben
On Fri, Jul 28, 2017 at 5:16 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kind regards,
Ben.
Hi Ben,
See:
Torben
directly
test database.
Jody and Nick,
Kind regards,
Director
New Zealand
Director
New Zealand
On 31 July 2017 at 17:06, Torben Barsballe <tbarsballe@anonymised.com>
Do you know which Sphinx version is on the build server?
I seem to be using Sphinx (sphinx-build) 1.4.4 and the docs built for me
recently.
Ian
Hi Ian
I believe it is using either 1.6.1 or 1.6.2.
Torben
On Mon, Jul 31, 2017 at 9:23 AM, Ian Turton <ijturton@anonymised.com> wrote:
On 31 July 2017 at 17:06, Torben Barsballe <tbarsballe@anonymised.com> wrote:
I seem to be using Sphinx (sphinx-build) 1.4.4 and the docs built for me recently.
Ian
sphinx@anonymised.com
On Mon, Jul 31, 2017 at 12:27 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Ian
Torben
Ian
Nick Stires
DevOps Engineer | Boundless
nstires@anonymised.com
Mobile: +1 561-713-0922
Looks like it’s installed via NPM, so should be easy to upgrade.
-Nick
On Mon, Jul 31, 2017 at 12:30 PM, Nick Stires <nstires@anonymised.com> wrote:
Hi Ian
Torben
Nick Stires
On Mon, Jul 31, 2017 at 9:23 AM, Ian Turton <ijturton@anonymised.com.403…> wrote:
Ian
Nick Stires
nstires@anonymised.com9…
I’ve just made a successful mvn -nsu clean install in docs with sphinx 1.6.3 but there are a couple of warnings that might break the jenkins build
sphinx-ignore-warnings:
[exec] Running Sphinx v1.6.3
[exec] loading pickled environment… failed: Can’t get attribute ‘WarningStream’ on <module ‘sphinx.util.nodes’ from ‘/usr/local/lib/python3.4/dist-packages/sphinx/util/nodes.py’>
[exec] building [mo]: targets for 0 po files that are out of date
[exec] building [html]: targets for 1 source files that are out of date
[exec] updating environment: 1 added, 0 changed, 0 removed
[exec] reading sources… [100%] index
[exec] /usr/local/lib/python3.4/dist-packages/sphinx/util/requests.py:72: UserWarning: Some links may return broken results due to being unable to check the Server Name Indication (SNI) in the returned SSL cert against the hostname in the url requested. Recommended to install requests-2.4.1+.
doing pip install requests==2.4.1 seems to fix them (seems like 2.2.1 is default on ubuntu)
and then it throws up some actual textual problems
[exec] /home/ian/code/geotools/docs/index/index.rst:2: WARNING: Duplicate explicit target name: “stable”.
[exec] /home/ian/code/geotools/docs/index/index.rst:2: WARNING: Duplicate explicit target name: “maintenance”.
[exec] looking for now-outdated files… none found
I’ll have a look later.
Ian
-Nick
Nick Stires
Hi Ian
Torben
Nick Stires
Ian
Ian Turton
Should psql be installed on the slave (as originally requested in this thread) or will you switch to a one-off manual configuration of the database?
Kind regards,
Director
New Zealand
