[Geoserver-devel] GeoServer Meeting 2017-10-17
Attending
  • Torben Barsballe
  • Kevin Smith
  • Jody Garnett
  • Andrea Aime
  • Ian Turton
  • Alessio Fabiani
Action items from Last Meeting- (done) Ben: Send email to arrange a CITE test breakout meeting
  • All: (thanks torben) Review swagger docs, fix outstanding errors
  • Done - see dataStore example
  • Ben and Jody: (done) add GWC refactoring comments to email thread
Agenda- GeoFence graduation
  • GeoServer 2.11.3 release
  • CITE tests switch
  • Code sprint 2018
  • GeoServer reporting GeoTools 18.x
Actions
GeoFence graduation
Emanuele wants to switch GeoFence to extension, GSIP incoming.
  • Long time community module
  • Q: Any additional REST API to document?
  • Yes, mig brated, …
  • Property file replacement resolver clashes
  • Now a conflict with GWC which uses same approach
  • Monitoring plugin has same approach
  • “property placeholders” are bad idea
  • Emanuele is removing property placeholders usage in GeoFence in the meantime
Discussion about not using property placeholders:
  • GWC has a use case for adjusting path between standalone and embedded
Release volunteers: Andrea and Jody
CITE: How do you want to do it?
  • Take the latest revisions and go?
  • Take WMS tests from Ares?
  • Or run cite tests locally, do not remember how
  • Wait on next agenda topic …
CITE tests switch
Close but no cigar…
  • All cite tests on Ares should not failing
  • Only WFS tests due to change to PostGIS 2.0 breaks
  • Can we rely
  • Ben has a suggestion, look at startup order, …
  • Follow up on email
  • Cite tests are trying to hit port 8080
  • GeoServer is running somewhere else (on 11010)
Code sprint 2018
Ideas:
  • XML parsing stuff
  • GWC refactor/improve/…
  • Comparison table with MapProxy, MapCache, TileCache
  • Is a sprint needed, see kevin’s email
  • code cleanup
  • import/export
  • Java 9
  • Jody hopes that a sprint is not needed for this?
  • Main tech risk has an outstanding proposal
  • See aaime’s email, buld wise it is not that far away (did not test running)
  • build wise (no run tests)
  • Dependencies upgrade? :slight_smile:
  • Raster API replacement and wrapper around JAI?
  • Explicitly for the C tribe code sprint; small targeted group with a goal of standing up initial interfaces
  • C tribe sprint places travel costs on attendent, funding goes to facility and food
  • REST API 2.0?
  • Kevin: give it a rest…
  • User Interface improvements?
  • Go through the ideas from victoria sprint
  • Many small changes to ease frustration, rather than big overhaul
  • GWC Wicket GUI? Or even freemarker …
Where/When:
  • C/Tribe sprint - expensive to attend personally, good for targeted activity JAI replacement
  • St Louis - cheap accommodation, boundless office, foss4g-na event
  • Victoria - good option for accommodation, cheap to attend personally, travel expensive
  • Astun Office in Epsom, nr London or South Coast of UK - Epsom accommodation is expensive South Coast is cheaper but no office space.
  • New Zealand - ben if fun but far away
  • New York - boundless office is small, accommodation is expensive
  • CCRi - may put us up, reach out Jim
pom.xml looks correct, might be an issue in the GeoTools jar manifest / version.ini
