[Geoserver-devel] GeoServer Meeting 26 July 2016
GeoServer / GeoTools Meeting 26 July 2016
Attending: Alessio, Jody, Torben, Andrea, Simone, Ian
Agenda:
  1. Bug Stomp Sprint Results
  2. Release Train and Blockers
  3. Getting a head(er) with OSGeo Legal
  4. FOSS4G Prep / Code Sprint
  5. Backup/restore pull requests
  6. Pull request review
Previous meeting actions:
  • (done) chris: repo being restarted with more capacity
  • andrea/kevin: Security vulnerability fix as per email discussion
  • torben/jody: community module YSLD, need documentation …
  • (done) Ian: see if MapServer want to sprint with us on SLD
  • (done) Ben: Security vulnerability fix as per discussion
results: https://osgeo-org.atlassian.net/secure/ConfigureReport.jspa?projectOrFilterId=filter-11000&statistictype=issuetype&selectedProjectId=10000&reportKey=com.atlassian.jira.plugin.system.reports%3Apie-report&Next=Next
For the prep we had 160 “new bugs”, we reviewed half of them (many were sent back for more details, and the ones that were ready added into the mix for the bug stomp sprint).
Majority of closed tickets is for old-new-features that were requested (often by community members where the budget did not come through). A new feature request from 2006 has not been popular enough to catch budget by now can ow be closed.
Actual bugs, 35 closed, 6 won’t fix, 3 cannot reproduce, 1 not a bug, 25 actually fixed:
https://osgeo-org.atlassian.net/issues/?jql=project%20in%20(GEOS%2C%20GEOT)%20AND%20status%20in%20(Resolved%2C%20Closed)%20AND%20resolved%20%3E%3D%202016-07-22%20AND%20resolved%20%3C%3D%202016-07-24%20AND%20issuetype%20%3D%20Bug%20ORDER%20BY%20resolution%20ASC
Next sprint?
  • Do it in conjuction with “foss4g post-sprint” on sat/sun
Action:
  • (draft) simone write blog post
  • (done) andrea/jody write some words about the foss4g post-sprint activities
Kevin has a patch in testing; we should be good to go later today.
Pull requests about it? Incoming?
Update from Kevin: OK, so I’ve run through a bunch of ad hoc tests with patched geoserver poking at things that use jsonlib and bean utils. Nothing seems broken.
Q: Did Kevin figure out what was breaking his local build? A: No!
Q: Did you get Kevin good tea? A: “yes”
Actions:
  • Devon/Jody expect to go ahead with the 2.9.x release today
  • Ben is up for the 2.8.x release
  • 2.7.x users are advised to udpate (we will word blog post appropriately “potential” rather than “actual”).
Ben and I met with OSGeo legal council last week, waiting on Ben to send email summary/write blog post.
TLDR: We are good with respect to headers, small advantage
  • headers not required for (c)
  • small advantage to headers is opportunity to document license
Actions:
FOSS4G Prep
pre-sprint:
  • Andrea to organize with QGIS sprint, engaged with qgis community, response is “interested” from the user community, and from some boundless developers
  • Andrea has a patch, need to learn python to write test
  • Need access to actual C++ developer, symbology that uses functions and property names does not have any mapping to SLD expressions current!
  • What kind of SLD export? Need a graduated approach:
    1.0 SLD
    1.1 SE / SLD
    GeoServer approach with vendorOptions
  • Lots of issues, non standard marks, random extension
    Filter where expression should be
    Units expressed in on screen mm
    Extra attributes where they should not be
  • QML vs SLD with respect to completness
  • Should we consider making our own XSD that includes vendorOptions? Not going to happen…
  • Or should we poke OGC to offically add vendorOptions? Timesink…
post-sprint:
  • bug stomp activity for near and far
  • Java 9 compatible (roll out a service registery replacement and test it to death)
  • Existing patches look to be license encumbered
Action:
  • Jody: set up a pre-sprint meeting to get organized here on QGIS SLD export
Workshop Prep
GeoTools workshops are both going ahead!
  • double check Java 8 use
  • datastore api change for streams (nice to have)
GeoServer Style Workshop
  • GSIP 149 Updated Style Page - in progress going well, expect to complete this week
  • migrate YSLD Reference to user manual
  • migrate YSLD Cookbook to user manual (can have one cookbook with tabbed examples). Would that approach still work for PDF? Not sure … and not sure if this is used. Although it has been requeted - assume examples would show up one after another in the PDF similar to note blocks. Worth an experiment…
Performance / Enterprise Setup Workshop
  • So popular it is being run twice!
  • Running on maintenance branch 2.8 so no prep needed
Multidimensional Workshop
  • Working as usual, against 2.8
Basic intro
State of GeoServer Presentation
  • copying previous format, will need all new functionality
GSIP-145 Voting needs to happen on the email list
Q: Discussion of “/rest/activity” api endpoint so we can share background tasks management?
Pros:
  • Advantage is single point to see what oint to see what server is doing
Cons:
  • Goes against rest goal of grouping by resource.
PR Parametic Catalog
PR reload config:
PR Community module: self contained, does not need review
Action:
  • Alessio - send email to geoserver-devel
Pull request review
Out of time - take this up next meeting
