[Geoserver-devel] Geoserver nightly build - Oracle JDBC NG
Hi Andrea,
I am getting a null pointer exception in line 1689 in StreamingRenderer.java as the GeometryDescriptor returned is null.
Am I missing something in the Oracle Spatial configuration that is causing the error.
Thanks and Warm Regards
Debasish Sahu
Debasish Sahu ha scritto:
Hi Andrea,
It would seem so yeah. Maybe the details of the table and user information can help use debug it.
Or if you have GS in a developer environment and can run it in
a debugger try to have a look in OracleDialect.getMapping
and see what happens with your geometry column.
Just to be sure: you do have a geometry column, it is accessible
by the current user, and properly indexed?
Andrea Aime
OpenGeo - http://opengeo.org
I do not think it is getting into the OracleDialect class as I could not find anything getting logged in the log files
I have pasted the log output here
2009-09-23 18:53:54,393 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2009-09-23 18:53:54,893 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2009-09-23 18:53:54,908 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2009-09-23 18:53:54,940 DEBUG [org.geotools.jdbc] - Grabbing table pk metadata: SELECT DIST_CODE FROM RUIS.LYR_DISTRICTBOUNDARY WHERE 0=1
2009-09-23 18:53:54,955 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2009-09-23 18:53:54,971 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2009-09-23 18:53:54,971 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2009-09-23 18:53:55,018 INFO [org.geotools.factory] - Factory implementations for category GridCoverageFactory:
org.geotools.coverage.grid.GridCoverageFactory
2009-09-23 18:53:56,127 DEBUG [org.geotools.styling] - number of fts set 1
2009-09-23 18:53:56,190 DEBUG [org.geotools.styling] - number of fts set 1
2009-09-23 18:53:56,362 DEBUG [org.geotools.renderer.shape] - Affine Transform is AffineTransform[[2.92986899731E-4, 0.0, 142.25235172550015], [0.0, -2.92986899731E-4, 1094.5457246812546]]
2009-09-23 18:53:56,362 DEBUG [org.geotools.rendering] - Computed scale denominator: 1.3569535373106829E12
2009-09-23 18:53:56,362 DEBUG [org.geotools.styling] - number of fts set 1
2009-09-23 18:53:56,362 DEBUG [org.geotools.rendering] - Geometry Attrnull
2009-09-23 18:53:56,377 ERROR [org.geotools.rendering] -
java.lang.NullPointerException
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1694)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:676)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1510)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1358)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:270)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:382)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:421)
Hi Andrea,
Andrea Aime
Debasish Sahu
That class cannot be dodged, it's just not logging anything.
Put a breakpoint where I suggested and follow from there, try to
see how the schema is being parsed.
If that does not work, put a breakpoint where you get the exception
Andrea Aime
