Hi guys,
I have noticed that the geoserver.org page’s section referring to the OSGeo project has a broken link for:
We are proud to be a recognized Open Source Geospatial Foundation project.
Referring to: http://osgeo.getinteractive.nl/projects/geoserver/
I think it should be:
https://www.osgeo.org/projects/geoserver/
Which is indeed the very same link attached to the OSGeo Project logo right below that statement.
I have create a PR to fix that:
https://github.com/geoserver/geoserver.github.io/pull/108
Hope it helps.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
