Hello,
I am using GeoServer1.7.5 and I set Tiles(100 to 300 Tiles) on google map using getMap request.
Its speed is slow .Is there any way to improve its performance.
Thanks & Regards
CSwami
Hello,
Thanks & Regards
CSwami
Can you be a bit more specific about what part is slow. Your description is a bit too generic for us to provide any useful feedback.
Also, have you seen this blog post:
http://blog.geoserver.org/2009/07/03/geoserver-175-critical-wms-patch/
It might be relevant in your case, not sure.
-Justin
CSwami wrote:
Hello,
Its speed is slow .Is there any way to improve its performance.Thanks & Regards
CSwami------------------------------------------------------------------------------
Enter the BlackBerry Developer Challenge This is your chance to win up to $100,000 in prizes! For a limited time, vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize details at: http://p.sf.net/sfu/Challenge
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I will add to justin's feedback a little bit.
We usually handle developer (code and build issues here) and leave off
configuration to the geoserver users list.
Have you read the following page on configuring geoserver for production?
- http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
There is also plenty of improvements to be had in optimizing your
styles for speed; and making use of simplified datasets at higher zoom
levels.
Jody
On Tue, Jul 7, 2009 at 10:39 PM, CSwami<cswami@anonymised.com> wrote:
Hello,
