[Geoserver-devel] GeoServer PMC meeting notes, June 7th 2022
GeoTools / GeoServer PMC meeting - 2022-06-07Attending
   Torben Barsballe
   Jukka Rahkonen
   Kevin Smith
   Andrea Aime
Actions from prior meetings:
   [DONE] Ian is working on GeoServer 2.21.0 release and announcement
Agenda
   1.
   Backport bot (and backport PR checklist?)
   2.
   Clean up on test code
   3.
   Build server migration progress
   4.
   GeoServer DNS management
   5.
   Code sprint
Actions
   Andrea to contact cholmes about DNS Zone Records for GeoServer
   Jody to reach out to Tom Ingold about the same(who Juan remembers doing
   this last time)
Revival of an old backport bot that stopped working due to system changes
QGIS has forked a version <https://github.com/m-kuhn/backport&gt; of this and
kept it working for them
Andrea has adapted the QGIS version and it seems to be working for GeoServer
The bot will create backport PRs automatically based on labels, e.g.
“backport 2.20.x” to create a backport targeting the 2.20.x branch.
Note: The bot is still being tested, use with caution
   Actions don’t appear to be run on backports. See
   https://github.com/peter-evans/create-pull-request/issues/48
      Requires a personal access token to be used
See email thread for details
   Part 1: merged to main, not yet backported to 2.21.x
      move test dependencies to src/pom.xml
      short list test dependencies we like
      awaitity clean up (allows fast machines to exist when done, while
      allowing build servers and slower machines more time)
         A few tests were waiting 30 seconds!
      note: Small effect on use of src/pom.xml as maven bill of materials,
      the dependency management for the test frameworks will carry over to
      "downstream" project including src/pom.xml
   Part 2: mock library dependency? We should choose one :slight_smile:
      Easymock - alive, some trouble with Java 17
      Mockito - also alive (far more popular), Java 17 happy, a bit nicer
      to use / quicker to use (no need to write verify() each time)
      https://www.baeldung.com/mockito-vs-easymock-vs-jmockit
      Google trends comparison
      <https://trends.google.it/trends/explore?q=easymock,mockito,jmockit&gt;
   Plan: Move build.geoserver.org to larger server
   <https://github.com/geoserver/geoserver/wiki/Move-build.geoserver.org-to-larger-server&gt;
      June 10th prep VM for transfer
      June 13th Purchase AX101 instance and transfer VM
      June 15th Verify builds and update DNS entry
      June 20th Restore jobs to were disabled to lack of space
   Juan has made a copy of the VM, converted to a different format
   Allessandro is going to try testing this in a new environment
   Purchase box and migrate after the test
We have the DNS, but not the zone record:
   https://trac.osgeo.org/osgeo/ticket/2756#comment:1
docs.geoserver.org:
   https://trac.osgeo.org/osgeo/ticket/2640
   Asks us to setup docs.geoserver.org website, before "resetup" the DNS
   entries
   Copy geotools job format and credentials
Action:
   Andrea to contact holmes
   done: Jody to reach out to Tom Ingold (who Juan remembers doing this
   last time)
Code sprint
Bolsena:
   Costs have been reduced (due to OSGeo support and sponsorship)
   https://www.osgeo.org/events/bolsena-code-sprint-2022/
      Idea: osgeo-api core and features cleanup? break up into modules
         review integration with spring mvc
         building links between resources
            not clear how to link - provide generic link without a format
            and let content negotiation happen
      Idea: database table management via importer
         Mode for "create", "update" consider adding a mode for "delete",
         see UpdateMode
         <https://github.com/geoserver/geoserver/blob/6e9e25c0c7cdda9ada9f33f8255130d3afc76801/src/extension/importer/core/src/main/java/org/geoserver/importer/UpdateMode.java#L13&gt;
         Andrea indicates the REST API may have an option … nope.
         Check out how coverage's manages granules - parameter called
         "purge" with "none", "metadata", "all".
      Idea: GSIP-202 Welcome Page Layout
CITE code sprint:
   not scheduled? We had hoped for June …
One thing we missed from last week’s missing, was asking for a volunteer for the release schedule.
Release GeoServer 2.20.5 / GeoTools 26.5 / GWC 1.20.3 is planned for next week; is anyone available to make this release please.
Aside: I tentatively updated the “release planning” to indicate GeoServer 2.22.x moving to Java version 11 and 17. Although this is waiting a proposal and PSC approval I thought it would be kind to advertise our intensions early for those planning ahead.
Jody Garnett
GeoTools / GeoServer PMC meeting - 2022-06-07### Attending- Torben Barsballe
  • Jukka Rahkonen
  • Kevin Smith
  • Andrea Aime
Actions from prior meetings:- [DONE] Ian is working on GeoServer 2.21.0 release and announcement
Agenda1. Backport bot (and backport PR checklist?)
  1. Clean up on test code
  2. Build server migration progress
  3. GeoServer DNS management
  4. Code sprint
Actions- Andrea to contact cholmes about DNS Zone Records for GeoServer
  • Jody to reach out to Tom Ingold about the same(who Juan remembers doing this last time)
QGIS has forked a version of this and kept it working for them
The bot will create backport PRs automatically based on labels, e.g. “backport 2.20.x” to create a backport targeting the 2.20.x branch.
  • Part 1: merged to main, not yet backported to 2.21.x
  • move test dependencies to src/pom.xml
  • short list test dependencies we like
  • awaitity clean up (allows fast machines to exist when done, while allowing build servers and slower machines more time)
  • A few tests were waiting 30 seconds!
  • note: Small effect on use of src/pom.xml as maven bill of materials, the dependency management for the test frameworks will carry over to “downstream” project including src/pom.xml
  • Part 2: mock library dependency? We should choose one :slight_smile:
  • Easymock - alive, some trouble with Java 17
  • Mockito - also alive (far more popular), Java 17 happy, a bit nicer to use / quicker to use (no need to write verify() each time)
  • https://www.baeldung.com/mockito-vs-easymock-vs-jmockit
  • Google trends comparison
Build server migration progress- Plan: Move build.geoserver.org to larger server
  • June 10th prep VM for transfer
  • June 13th Purchase AX101 instance and transfer VM
  • June 15th Verify builds and update DNS entry
  • June 20th Restore jobs to were disabled to lack of space
  • Juan has made a copy of the VM, converted to a different format
  • Allessandro is going to try testing this in a new environment
  • Purchase box and migrate after the test
docs.geoserver.org:
Action:
  • Andrea to contact holmes
  • done: Jody to reach out to Tom Ingold (who Juan remembers doing this last time)
Code sprint
Bolsena:
  • Costs have been reduced (due to OSGeo support and sponsorship)
  • https://www.osgeo.org/events/bolsena-code-sprint-2022/
  • Idea: osgeo-api core and features cleanup? break up into modules
  • review integration with spring mvc
  • building links between resources
  • not clear how to link - provide generic link without a format and let content negotiation happen
  • Idea: database table management via importer
  • Mode for “create”, “update” consider adding a mode for “delete”, see UpdateMode
  • Andrea indicates the REST API may have an option … nope.
  • Check out how coverage’s manages granules - parameter called “purge” with “none”, “metadata”, “all”.
  • Idea: GSIP-202 Welcome Page Layout
CITE code sprint:
  • not scheduled? We had hoped for June …
Hi Jody, me and Alessandro can take care of it… however, we cannot do it right now, nor next week: we’ll release it around the 27th.
Is that fine with everyone?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
