Dear Members,
I have installed Geoserver 2.6 and Post 2.0. I added the layer as WMS and the layer disappears and changes opacity when zoomed out on layer preview on openlayers.
Kind Regards,
Wondie
Dear Members,
Kind Regards,
Wondie
On Fri, Jun 19, 2015 at 4:22 PM, Wondimagegn Tesfaye <wondim81@anonymised.com>
wrote:
Dear Members,
on openlayers.
Changes opacity? Anyways, try disabling the database on the fly
generalization option in the postgis store configuration
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you for the help Andrea. I disabled on the fly generalization option and now, the disappearance has stopped but the opacity still lowers when I zoom out. Is there any other fix for it?
Thanks!
On Fri, Jun 19, 2015 at 6:32 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jun 19, 2015 at 4:22 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
Dear Members,
Changes opacity? Anyways, try disabling the database on the fly generalization option in the postgis store configuration
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Jun 19, 2015 at 9:02 PM, Wondimagegn Tesfaye <wondim81@anonymised.com>
There is no relationship between opacity and zoom level (unless you put one
in your SLD, that is), I believe you're explaining as opacity something
that is not opacity at all. Can you show some screenshots so that we can
see what you mean?
Ing. Andrea Aime
@geowolf
Technical Lead
It is good to know that. Now, I am even confused, The problem has disappeared. The only thing I did is, I added stroke rule with color, opacity and width, and color, related to my other issue. Now, the opacity doesn’t change and it is opacity 1.0.
Thank you very much for the help!
On Fri, Jun 19, 2015 at 10:53 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jun 19, 2015 at 9:02 PM, Wondimagegn Tesfaye <wondim81@anonymised.com> wrote:
There is no relationship between opacity and zoom level (unless you put one in your SLD, that is), I believe you’re explaining as opacity something
that is not opacity at all. Can you show some screenshots so that we can see what you mean?
Ing. Andrea Aime
@geowolf
Technical Lead
