GeoTools / GeoServer PMC meeting - 2021-11-23Attending
Torben Barsballe
Jody Garnett
Kevin Smith
Andrea Aime
Actions from last meeting:
[DONE] Release Managers: Copy Release notes for active branches, and
update website release layout
Torben: Ask on GeoServer Gitter about space increase (up to 500G) for
build server. JENKINS_HOME is currently 173G, and the server only has 250G
total.
[DONE] Torben: Propose switching to 17:30 UTC on mailing list.
Agenda
1.
Jenkins Java 11 Upgrade (delayed)
2.
Meeting Time Discussion (continued)
3.
Java 17 support
4.
Translations
Actions
Waiting for 2.20.1 release, which is done. Backup wrapping up (remote
backup).
Then should be good to go.
Idea:
Ask for more space on server; 500 GB total
cite jobs may need clean up
jobs with local repo try to store in workspace, can we exclude
repositories?
Aside: windows installer permissions should be fixed (was unable to delete)
Change to CEST timezone so we do not have to update twice a year … Tested
for this meeting, seems to work fine.
Java 17 support
There is a PR, wow! Thanks bjornharrtell and aaime
geotools is … done/merged and PR check in place
geoserver .. a few “opens” added for java base packages
https://github.com/geoserver/geoserver/pull/5248
opens are needed to build, for example xstream needs access to
everything
marlin:
mentioned in
adoptium temurin Java 8 - now includes Marlin
https://adoptium.net/migration.html “Work is planned at Adoptium to
either backport Marlin to OpenJDK 8 and/or minimize any display issues
between the two.” ← this is now complete
EOL dates for Java versions <https://adoptium.net/support.html>\.
Propose officially migrating to Java 17/Jakarta packages by end of 2022 /
GeoServer 2.22.0 Release.
Will need Spring
<https://spring.io/blog/2021/09/02/a-java-17-and-jakarta-ee-9-baseline-for-spring-framework-6>,
Wicket to use Jakarta as well for the Jakarta part.
Spring is targeting Q4 2022, so this timeline may be infeasible
Wicket support is in progress
<https://issues.apache.org/jira/browse/WICKET-6882> , targeting Wicket
10.0.0
Now that GeoTools is supporting Java 17, we should add a Java 17 runtime to
Jenkins.
Also add info to the GeoTools compatibility matrix.
https://docs.geotools.org/latest/userguide/build/install/jdk.html
(page could be simplified now)
Translations
Jody has had no capacity to follow up, was focused on release.
Andrea tried to enable github integration … feedback was that this did not
work. But need more detail ...
Links:
https://www.transifex.com/GeoServer/geoserver/
https://www.transifex.com/GeoServer/geoservertestgithub/
Also language chooser PR <https://github.com/geoserver/geoserver/pull/5388>\.
need CSS/UI help to make it look better
