[Geoserver-devel] GeoServer PSC Meeting notes April 23 2024
GeoTools / GeoServer PMC meeting - 2024-04-23### Attending- Torben Barsballe
  • Andrea Aime
  • Jody Garnett
  • Jukka Rahkonnen
  • Peter Smythe
Actions from prior meetings:- [DONE] Andrea: send an email for the release manager
  • [DONE] (no response yet) Jody: Reach out to Jo Cook (Astun) regarding core contributor status
  • [DONE] Jody: Propose adjustments to contributor policy requiring interaction on an individual (not organization) level
Agenda- Crazy issue with Azure blobstore, and how to prevent it
  • GRIB backwards compatibility broken (with silver lining)
  • Mkdocs conversion getting it moving again
  • GSIP 224 discussion
  • Roadmap communication and chit-chat
Actions- Jody: Make a PR for GSIP 224
  • Peter: Make a similar proposal for GeoTools
  • Jody: Make a PR for geoserver-users transition to discourse
GWC Report makes a massive amount of requests to Azure blob store:
  • Deleting a layer / gridset resulted in an infinite loop due to a … jackson upgrade resulting in a regression
  • API uses JSON, we use jackson to parse the JSON including the token to page through results … and token was null when reaching the end
  • Jackson upgrade changed null to empty string, so infinite loop
Can we run tests?
  • There is a cost (paid account), but for an infinite loop this would be expensive …
  • emulator + client library are a matched set
  • so we need to migrate to newer client library to make use of the API
  • Azure / S3 / etc… all have this lack of infrastructure to test against problem
There is a public ticket here, but has not attracted interest / fix…
  • 33000 requests per min is expensive!
  • Fix was to check for empty string
This is a good example of where the PSC can ask for funding?
  • Would have to set a hard limit of build server use (for each day a specific number of calls etc…)
  • This is also an example of shared risk, someone found the 33000 requests per min and reported it (so it was available for others to see and work on).
  • So we could estimate the cost to setup a “cloud infrastructure” testing …
GRIB backwards compatibility broken (with silver lining)- Follow on to this from a few meetings ago …
  • Manual upgrade process documented (also for GeoTools)…
  • Can kind of guess and rewrite the variable names
  • But the time format changes so still some risk…
  • We do expect time format to change once again (hopefully before September release cycle)
  • With all this … success we are now on a supported version netCDF library
  • Quite a bit faster (example 20x), especially on a network …
mkdocs conversion getting it moving again- Jody is back from travel and available to work on this again
  • available on pypi: https://pypi.org/project/mkdocs-translate/0.4.0/
  • tested by Andrea, can make it run, however breaking on pandoc
  • jody is using pandoc 3.1.7 (installed via homebrew)
  • latest is 2 weeks ago: pandoc 3.1.13 (pip only has up to 2.3, Mint up to 2.9)
  • GeoCat will provide a tester to help with the remaining A/B testing
Examples of the kind of RST fixes to expect:
GSIP 224 discussion
GSIP 224 clarification about be grateful to companies (while explaining that commit access is extended to individuals):
GeoServer is grateful that organizations of all shapes and sizes support our project with in-kind participation of their employees. Extending commit access is made to individuals directly based on their expertise demonstrated over time.
Proposal is approved
  • Jody will take an action to make a PR for GSIP224
  • Peter to make a similar proposal for GeoTools
2024 Q1: https://geoserver.org/behind%20the%20scenes/2024/01/03/roadmap.html
https://github.com/geoserver/geoserver/wiki/Maintenance-%26-Roadmap
2024 Q2: jody is considering making another news announcement.
  • goal would be to emphasis the in-kind contributions / commitment
  • any progress…
  • fundraising progress … not very much sadly
Q: What roadmap items can be worked on now?
  • As spring-framework upgrade is “stuck” pending funding / in-kind?
spring-security / spring-oauth-client upgrade:
  • this work can happen now no need to wait…
  • GeoCat asks if there are interested parties to work on this activity?
  • Considering in-kind participation if others are willing…
  • aside: email with Andreas Watermeyer offering to work on the upgrade. No status update since January
wicket:
  • Upgrade to Wicket 9 can happen now no need to wait…
  • Brad has made a lot of progress towards Wicket 9
  • GeoCat will offer in-kind A/B testing which we understand is needed
  • Open: Brad asked for assistance with the WicketDialog rewrite
  • Or can just suppress its deprecation for Wicket 9, and do the work for Wicket 10…
  • Q: Is anyone available to organize / plan with respect to the release cycle?
  • Andrea prefers to merge close to September (to avoid extra backport overhead…)
  • Andrea has been keeping this up to date with main
ImageN:
  • Java 17 is upset running JAI due to javax package
  • This is also something that can be worked on now, no need to wait …
  • In-kind thus far:
  • GeoCat is interested in this one also, provided it is a good time
  • Andrea made some roadmap planning ideas on JAI-EXT
Q: Mass reformat with Palantir?
  • Still a good idea, wait until after Wicket upgrade :smiley:
Q: What about discourse?
https://discourse.staging.osgeo.org/c/geoserver-users/12
  • testing…
  • nice it works with OSGeo User ID
  • OSGeo user ID login did not work for Peter
  • nice it works with GitHub
  • feedback
  • modern / looks / better
  • alternative:
  • github discussions is okay, with any discussions occurring closer to development. May be a good replacement for geoserver-devel …
Discussion: how to replace the email list?
  • email subscribers switch from sourceforge to discourse
  • get a feed of emails similar to mailman, and an address to reply to …
  • not sure we can test this on staging? It was disabled …
What can we expected:
SAC joins the chat
  • They could set up a mirror from sourceforge …
  • Setup an email address and subscribe it to sourceforge…
  • Send email to discourse and it would not send to sourceforge…
  • Q: How do they sign up discourse geoserver-users?
    1. Setup a “geoserver-users” group
    1. Allow users to join freely …
    1. The group is https://discourse.staging.osgeo.org/g/geoserver-users
    1. Associate a user geoserver-users@anonymised.com with the group, so that email sent to this address is added to the discourse group
Actions: Make a proposal?
  • Define a date to shut off geoserver-users@anonymised.com email list?
  • Setup production geoserver-users@anonymised.com
  • Keep both running for a month, use this as an oppertunity to remind people to transition …
  • Collect a mailman dump for the month of overlap, and re-update discouse
  • Shut off source forge
How to transition as an individual:
  1. Login to discourse using (github / osgeo userid / oauth)
  2. Register to the geoserver-users@anonymised.com group
  3. You automatically watch the group you join and get email notifications
  4. You can reply to email from geoserver-users@anonymised.com…
  5. Just like a mailing list …
  6. Unsubscribe from https://sourceforge.net/projects/geoserver/lists/geoserver-users/unsubscribe
