[Geoserver-devel] GeoServer PSC Meeting Notes, Dec 19 2023
GeoTools / GeoServer PMC meeting - 2023-12-19### Attending- Torben Barsballe
  • Kevin Smith
  • Andrea Aime
  • Gabriel Roldan
  • Jody Garnett
Actions from prior meetings:- Jody: Submit budget + sponsor activities to board (copy geotools example)
  • [DONE] Jody: Make a motion to sponsor Marlin and GISSA 2024
Agenda- Release 2.23.4 Planning
Actions- Jody: Call for vote on GSIP 221, plan to update early Jan
  • Andrea: warn people about Java 21 build requirements and start merging PRs. Also make a GWC 21 PR.
Looks like we have a volunteer - Peter! Thank you Peter!
He will need backup on GWC (if there are any changes)
  • checking: yes an update is needed
OSGeo Budget Request / Sponsorship Opportunities
The OSGeo elections are stalled on communication - so the current board has not been replaced
Jody would like to plan a blog post for January 1st (new calendar year).
  • please provide feedback to the list; or contact jody directly with your input
  • there will be a pull-request for review/feedback
GSIP 221 mkdocs
https://github.com/geoserver/geoserver/wiki/GSIP-221
Q: Doc freeze?
Yes - a good idea when proposal is accepted
  • it is quick to convert as I have script? So can we freeze for 1-2 days after successful doc conversion
Q: Do we just want to update main? Or the active branches?
  • A: Update the active branches
Q: version selector version VS stable URLs
Action: Jody will call for a vote on the proposal, plan to doc freeze the 1st week of January
Java 21 work ongoing
https://github.com/geotools/geotools/pull/4591
Q: Allow to Java 21 build to fail?
  • A: No, go for broke :slightly_smiling_face:
This handles people who just install java … and end up with Java 21.
Q: Why is this working? I thought JAI would break things …
  • A: We are not running QA - indeed if we build with Java 17 or Java 21 the QA will fail
  • We compile with Java 11, and then Java 17 and Java 21 will load the older classes with less strict requirements
How to go with it? Just go with a warning that code will build with java 21 in the actions.
Use maven CI friendly versions
See https://maven.apache.org/maven-ci-friendly.html
Andrea +1
Requires Maven > 3.5.0
Jenkins is showing two different maven versions:
We should probably be more consistent here, but in any case Jenkins supports this tool as-is
Security Vulnerability Roundup
The Coordinated Vulnerability disclosure policy is going fine.
Notes:
  • sikeoka has been working on several fixes
  • gabe has one to look at
