[Geoserver-devel] GeoServer PSC meeting notes, July 18th 2023
GeoTools / GeoServer PMC meeting - 2023-07-18Attending
   Kevin Smith
   Andrea Aime
   Jody Garnett
Actions from prior meetings:
   None
Agenda
   GS 2.23.2 release train
   Bolsena planning / budget
   IAU work nearing completion
   Beating shapefile at its own game
ActionsGS 2.23.2 release train
Ian doing the release, Andrea/Jody happy to help with GWC release and Jody
with release announcements.
Hiccup with Java version in release script? Maybe, Jody is checking.
Looks like Ian compiled with Java 17 on his local machine.
Ian will ask for gwc release when ready.
Jody asks that the geoserver blog post script be used / tested again :slightly_smiling_face:
Bolsena planning underway:
   Andrea confirmed
   Jody confirmed
Budget:
   OSGeo has been inconclusive with respect to their commitment
      they are going to clarify next board meeting, which is after travel
      plans / confirmations are needed
      proceed anyway and trust osgeo or geoserver budget to help cover
      activity
Discussion:
   geometry was progressing okay
   <https://github.com/geotools/geotools/tree/remove-opengis-geometry&gt;
      compare to geoapi 3.0 where they a Geometry placeholder
      We can simplify Feature model to return JTS Geometry directly now
   thinking
      org.geootools.api.filter interfaces were maintained, with
      org.geotools.filter interfaces dropped
      The same approach can be used for styling, dropping the geotools
      interfaces
   Time permitting:
      Simplifying the Envelope / BoundingBox / ReferencedEnvelope
      situation, not as easy as using ReferencedEnvelope / ReferencedEnvelope3D
      everywhere
      Styling immutability similar to Filter immutability
Merged? Almost
   postgis, geopackage in progress
   srs list PR is created <https://github.com/geoserver/geoserver/pull/7033&gt;
   (thanks)
   there will be lots of places left over to finish over time
https://github.com/flatgeobuf/flatgeobuf/pull/275
With this PR FlatGeoBuf renders faster than before, and faster than
shapefile too (dataset is 1.5GB shapefiles with 4 million polygons, with
interpolate on one of the attributes to set the fill color):
   Shapefile renders in 43 seconds
   FGB renders in 34 (did not finish earlier)
