[Geoserver-devel] GeoServer PSC meeting notes, July 20th 2021
GeoTools / GeoServer PMC meeting - 2021-07-20### Attending
Andrea Aime
Torben Barsballe
Kevin Smith
Jody Garnett
Actions from last meeting:- [DONE] Andrea: ask on list about backport of caching skip on nearest match or no match (and also on default value)
Agenda1. GeoTools 25.2 / GeoServer 2.19.2 update
  1. Wicket / Freemarker huh?
  2. CITE PR, merging
  3. Simplify the PR template
Actions- Andrea: Create a PR for the GeoTools template. Others to review.
GeoTools 25.2 / GeoServer 2.19.2 update- http://geotoolsnews.blogspot.com/2021/07/geotools-252-released.html
Ian reported 2.19.1 is still shown:
  • will update the yaml file
  • Also some rendering issue on the archive page, in progress
GeoTools bundles, dependencySets worked well, and should be considered for GeoServer extensions next.
Wicket provides velocity integration…
  • VelocityPanel integration provide a very simple map + freemarker —> component
  • We have not implemented freemarker anywhere? Any utility class …
  • Nope, integration will need to be created from scratch
Welcome page processes service endpoint
  • There is no clear link “WMSInfo” / “WFSInfo” and their their service endpoint
  • Just a naming convention, may break out something more explicit
    (if so will add to the proposal)
  • ServiceInfo (id generated)
  • Service objects (id), not sure if namespace is used
  • Q: what service objects are valid for a workspace (or a layer)?
  • Check the dispatcher at runtime see how it goes
  • Check some dispatcher callback that looks this up in a generic way
  • Uses reflection to look for getServiceInfo() method and call it if available
    (so this convention only, consider a ServiceInfoProvider interface here)
  • Idea: Service object namespace? See GEOS-5132 (nope this is for WFS dispatch)
CITE PR, merging
Yes, please do so!
And DONE!
On Tue, Jul 20, 2021 at 7:24 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
  • Andrea: Create a PR for the GeoTools template. Others to review.
GeoTools PR: https://github.com/geotools/geotools/pull/3586
GeoServer PR: https://github.com/geoserver/geoserver/pull/5163
