GeoTools / GeoServer PMC meeting - 2023-06-06Attending
Torben Barsballe
Andrea Aime
Jody Garnett
Actions from prior meetings:
N/A
Agenda
1.
H2 removal backport
2.
Release preparations
3.
FOSS4G planning
4.
Bug splat / chit chat
Actions
H2 removal backport
Starting to get backported
it will ignore the existing h2 database (leaving it on disk), and create
a new hsql database
update notes describe the manual step (only required if you have
external h2 server)
Notes:
netCDF still remains using H2, ideas/funding welcome
GeoFence also uses H2 as the default storage for rules but it’s possible
to migrate
H2 was intended to be the second version of HSQL, and then it wasn’t …
(HSQL has a version 2 now which is not H2).
Peter Smythe has volunteered (thanks!) Jody is going to help guide
Petre needs access to jira access
Build server
Website commit access
Jody will probably do the ruby step
Jody automated making a release announcement post, so something to test and
provide feedback.
FOSS4G planning
Jody is running a workshop
code-sprint:
going to do the first stage of opengis transition stuff
sprint priority - identify decisions that need to made
referencing - integrate interfaces into geotools packages
metadata - used in a few places in referencing (used for citations)
remove geometry (keep bounding box and ordinate used by referencing)
filter / expression / style have immutable / mutability boundary
presently we clone / copy all the time as we can never be sure
idea: fix the javadocs to be clear on what is happening
idea: see proposal for using builder to “clone” for editing
aside: We should check back on OGC board meeting; they may provide
input/funding
https://github.com/geotools/geotools/wiki/Remove-OpenGIS
action:
jody: Ask user-list for examples
https://osgeo-org.atlassian.net/browse/GEOS-10983
coverage.xml generated with srs actually can read
but the raster store cannot actually connect, user defined projection
a solution is to ignore user defined projection if possible (example
vendor WKT geotiff tag)
https://github.com/geoserver/geoserver/pull/6900
geopackage output cleanup tmp files
