[Geoserver-devel] GeoServer PSC meeting notes, March 29th 2022
GeoTools / GeoServer PMC meeting - 2022-03-29Attending
   Andrea Aime
   Jukka Rahkonnen
   Torben Barsballe
   Jody Garnett
Actions from prior meetings:
   AA: ask Steve about joining security team [TODO]
   JG: ask the PSC about Steve joining security team [DONE]
Agenda
   Log4J2 update
   Discuss admin access checks in processes
   kml-ppio graduation
Actions
Log4J2 update
   Jody working on GWC
      respond to feedback today, thanks for review Ian and Andrea
   GS updates incoming
      So far working with “no change” (ie just using reload4j for log4j 1.2
      API)
   Performance of logging wrappers may be improved later
   gt-metadata splitting? hard to do, maybe later
geoserver data directory:
   data directory format, how does migration work?
      test cases read legacy data directory, issue events, which are saved
      in format
   do we need to look at this for logging config
      PRODUCTION_LOGGING.properties → PRODUCTION_LOGGING.xml
         discussion on handling customizations
Reference PR: https://github.com/geoserver/geoserver/pull/5735
   checks security during writing a process
   shows a gap in our security model, and is extra work for process writers
   REST API used to allow fine grain control with “ant process”?
Discussion
   Direct admin checks in wicket admin? there is one in geoserver base
   page..
      workspace admin, and base admin, ..
   Q: Can we provide processes with a “SecureCatalogue” which performs
   security checks on data access?
      May do more damage than good, …
      Lots of danger of regressions, …
   allowing admin access is “x” (not “r/w” granularity)
   Go ahead with current approach, the “proper” way is not worth the
   side-effects
kml-ppio graduation
KML read/write for WPS :slight_smile:
   1.
   Alternative one, merge into wps-core → wps becomes dependent on wms,
   nope!
   2.
   Alternative two, merge into wps-downlaod → what if I just need kml
   though?
   3.
   Then upgrade as-is, even if small
Compromise (thanks Torben): graduate and package in the wps zip, but do not
make wps-core depend on it.
Chit Chat
   Hey jody had a small documentation proposal here:
      https://github.com/geotools/geotools/wiki/Change-tutorial-and-example-code-from-public-domain-to-CC0
      https://github.com/geotools/geotools/pull/3823
   Discussion on duplicating boilerplate QA profile code into many small
   tutorials
      Also perhaps for integration tests (see log4j upgrade branch)
      Updating pmd version number in many places etc…
   Idea:
      Can use dependency scope import to “include” some common QA stuff
      (rather than copy and paste).
