GeoTools / GeoServer PMC meeting - 2024-05-21### Attending- David Blasby
Peter Smythe
Jody Garnett
Jukka Rahkonen
Actions from prior meeting:
[DONE] Jody: Make a ticket about GROUP_ADMIN not having permission to create a new user (GEOS-10938)
[DONE] Jody: Make a ticket on clean up of admin roles and constants (GEOS-11389)
[DONE] Jody: Open a ticket to refine Demo Page Javascript rewrite (GEOS-11390)
Agenda:
repo.osgeo.org maintenance
build status
Why do checks fail, what is the process to handle failures?
Dependabot https://github.com/geoserver/geoserver/pull/7637 process?
release status
discourse migration
Clean up old branches, keeping 2.2.x, ones with open PRs?
TestWFSPost servlet removal (replace w/ 100% JS). Demo Request, WCS Request, WPS Request
mkdocs
Upgrade Nexus to v3.68.1 for CVE-2024-4956:
Asked to reset gsbuild user (done)
contacted torben, updated build.geoserver.org settings.xml
Asked to reset gsdocker user
contacted weskamm@anonymised.com ?
build status
Q: Why do checks fail, what is the process to handle failures?
Jody broke last week (did not run -DQA checks when backporting using cherry-pick)
Had to close and open backports to “rebase” effectively
Checks that are needed across projects (geotools api change; that needed a geoserver
For intermittent failures
Quick: rerun failed test …
Why: Each example needs investigation
windows locked file is a common failure with older file system?
Perhaps some state changed (environmental variable) that affects another test…
Perhaps opening a port → randomise the port used (minimise error)
Thanks Andrea for fixing build (twice) recently.
About backports:
Yes - if we can (example dependabot)
New functionality?
https://docs.geoserver.org/latest/en/developer/policies/pull_request.html
If the new feature is suitable for backport, you may ask on the developer list after a 1 month. -
Q: Add this to CONTRIBUTING.md also?
release status
Delayed: Waiting on PR reviews and build stability
PRs:
https://github.com/geotools/geotools/pull/4773 Geometry type mismatch in WFS 1.1.0
version updates of stuff? Some from GeoTools…
discourse migration
This is ready to move
Marketing committee made the change, can see their instructions
We need similar instructions in our docs, and then inform the user-list
Clean up old branches, keeping 2.y.x, ones with open PRs?
In general we keep in case people need an emergency patch
- We can see examples where release are made for archived releases
Stale PRs get removed, with the idea that the branch is there if anyone wishes to recover the work. So deleting the branch may not be kind?
Stale working branches?
Developers should remove when activity is complete
It would be nice to clean these up, I do not know of anything automatic
Ones with “stale” PRs may be worth keeping?
Some from big refactors are useful to keep (example refactor code sprint)
Perhaps these could be placed in to a folder?
Positive response, nice work David.
Peter had feedback on workflow and button order consistency between Demo Request page, WPS Builder, WCS Builder.
