GeoTools / GeoServer PMC meeting - 2023-09-26Attending
Torben Barsballe
Jody Garnett
Jukka Rahkonnen
Andrea Aime
Actions from prior meetings:
action: Discuss with Alexandre Gacon on the geoserver-devel list about
translation (done)
action: Ask on the geoserver-devel list for assistance setting up new
branches and jobs (done)
Agenda
GeoServer 2.24-RC / GeoTools 30-RC
GSIP 220 - Revised Security Policy and CVE handling
Actions
GeoTools 30-RC:
thanks to downstream projects you are excellent
Released:
https://geoserver.org/announcements/2023/09/25/geoserver-2-24-RC-released.html
twitter (aaime)
mastodon (jody)
linkedin (jody)
Community modules:
script worked well added instructions for next time
consider updating script to block out community module tickets from the
main list
action: gabe did not have docs for geoserver-acl
action: GPL license is not included
GEOS-11134 - GeoServer 2.24-RC packaging feedback
<https://osgeo-org.atlassian.net/browse/GEOS-11134>
When do we wish to make the release?
two weeks → October 10th?
Docker image with ogcapi features
docker run -it -p8080:8080 --env INSTALL_EXTENSIONS=true --env
COMMUNITY_EXTENSIONS="ogcapi-features" docker.osgeo.org/geoserver:2.24.x
Welcome to GeoServer 2.24-RC
Initialize /opt/geoserver_data/ from data directory included in
geoserver.war
Starting download of extensions
URL does not exist: /geoserver-2.24-RC-ogcapi-features-plugin.zip
Finished download of extensions
Starting installation of extensions
Finished installation of extensions
lol:
2.24.x should pull from nightly server
stable should pull from source forge
it got confused checking 2.24-RC and thinks it is a “snapshot”
https://build.geoserver.org/view/release/job/geoserver-release-docker/390/parameters/
https://build.geoserver.org/view/release/job/geoserver-release-docker/390/console
Jody fails bash if/else check:
https://github.com/geoserver/docker/blob/master/build/release.sh
The experiment with creating a CVE number has helped communication with
national CVE Numbering Authority, they recommend our policy is clearly a
“Coordinated Vulnerability Disclosure” (since we disclose when patch is
ready on stable and maintenance).
Be clear we can provide CVE number
Be clear we time our announcements in SECURITY.md file
action:
jody: update security.md file with “Coordinated Vulnerability
Disclosure” heading
aaime: credit steve on jai-ext jiffle vulnerability? it was already one
Steve wished credit on https://github.com/advisories/GHSA-59x6-g4jr-4hxc
this was externally reported so we do not have direct control
jody did a pull request, perhaps steve can do the same?
jody also asked MITRE three times to update the original (
https://nvd.nist.gov/vuln/detail/CVE-2023-35042)
aside: Credit Steve on:
GHSA-59x6-g4jr-4hxc
GHSA-fh7p-5f6g-vj2w
Update prior security vulnerability sections:
https://geoserver.org/announcements/2023/07/21/geoserver-2-23-2-released.html
publish the new CVE number
update security vulnerability sections with CVE number
h2 no longer included; not really a vulnerability as no known exploit.
but we can make a heading for it.
Chit chat
Roadmap - Java 11 becomes EOL in 2024?
Can we just run with Java 17 and Tomcat 9? I think so …
Compiling for Java 17? JAI → ImageN?
We have the code, but *no* test cases were provided (and no native
code)
This is clean-room code so we need to write out own test-cases
https://github.com/eclipse/imagen
Tomcat 10:
someone had success with automatic conversion on the email list? Huh?
How …
uses bytecode on the fly hacking …
“successful” in startup, but I would not trust in production, ..
JavaEE:
requires Java 17 because of spring6, then need to do everything at once,
https://github.com/geoserver/geoserver/wiki/Jakarta-EE
TOO MUCH to do in one go? can we split it up …
Phase 1
Wicket 7 → Wicket 9
JAI → ImageN
spring-security-oauth modules
Phase 2
Java 17 minimum
Phase 3
JakartaEE
spring-framework?
action:
Jukka: blog post about this
