Does anyone know why the git checkout on jenkins if failing for the 2.7.5 release?
http://ares.opengeo.org/jenkins/view/release/job/geoserver-release-publish/47/console
I don’t recall ever having a problem with this step before
Ian
Ian Turton
Ian
Ian Turton
I might be wrong, but I see Jody releasing too… and I don’t think that
two releases can go out in parallel, as release and release-publish
retain some state on a local checkout on the build server.
If that’s the case, you may have to redo the release job too to
re-instate the correct state for your release.
Then again… maybe I’m wrong and it’s something else (but don’t know what)
Ian
Ian Turton
Geoserver-devel mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Those files were all changed by my Java 8 upgrade on master. I think we have a race condition in release-publish because it switches to master and pulls (when I think it should only fetch) even when it is on a non-master branch. If files that are processed in the release job (release tag updates in poms and installers) are changed on master between the running of release and release-publish, there may be a conflict.
I do not think this is a problem caused by Jody's concurrent release.
Andrea, I agree with your proposed solution: Ian, please try rerunning the release job. Hopefully that will clear the workspace and resolve the conflict.
Kind regards,
Ben.
On 22/12/15 09:26, Andrea Aime wrote:
I might be wrong, but I see Jody releasing too... and I don't think that
retain some state on a local checkout on the build server.If that's the case, you may have to redo the release job too to
re-instate the correct state for _your_ release.Then again... maybe I'm wrong and it's something else (but don't know what)
AndreaOn Mon, Dec 21, 2015 at 6:12 PM, Ian Turton <ijturton@anonymised.com> wrote:
release?http://ares.opengeo.org/jenkins/view/release/job/geoserver-release-publish/47/console
I don't recall ever having a problem with this step before
Ian
Ian Turton------------------------------------------------------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-devel------------------------------------------------------------------------------
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
