[Geoserver-devel] GeoServer release script failing
the 2.7.2 release job is currently failing.
The first failure was caused by the removal of the src artfact, without a corresponding
change in the release scripts, that were still expecting it. I believe I fixed it.
Now instead it’s failing to launch the win installer build:
starting installer jobs
executing installer job [http://162.209.53.106:8080/job/geoserver-installer/buildWithParameters?TAG=2.7.2&token=buildme](http://162.209.53.106:8080/job/geoserver-installer/buildWithParameters?TAG=2.7.2&token=buildme) with credentials build:c7df8777ad146449f39272c596e963e4
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
executing installer job [http://199.19.86.219:8080/job/geoserver-installer/buildWithParameters?TAG=2.7.2&token=buildme](http://199.19.86.219:8080/job/geoserver-installer/buildWithParameters?TAG=2.7.2&token=buildme) with credentials build:7babda1c4cf05ee099baa3d4c6579dab
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:02 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:03 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:04 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:05 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:06 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:07 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:08 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:09 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:10 --:--:--     0curl: (28) connect() timed out!
Build step 'Execute shell' marked build as failure
Finished: FAILURE
That said, it seems the artifacts managed to get on the release folder, so
while we won’t have a windows installer, the release can proceed anyways:
http://ares.boundlessgeo.com/geoserver/release/2.7.2/
Anyone wants to give those artifacts a kick, and could someone check what’s up with
the windows installer build?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It looks like the first one is the Windows build, and the second is the OS X build. It turns out that boundless recently updated the OS X build server, and http://199.19.86.219:8080 no longer exists. I have updated build.properties with the new IP, so hopefully a new build will be sucessfull.
Torben
On Wed, Jul 22, 2015 at 9:06 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Finished: FAILURE
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 22, 2015 at 7:28 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
<http://199.19.86.219:8080/job/geoserver-installer/buildWithParameters?TAG=2.7.2&token=buildme&gt;
<https://github.com/geoserver/geoserver/commit/ab7cf65e9c2480541cea013e4b86c13213a2bb0f&gt;
sucessfull.
Ah ok... shall I kick it again then?
Ing. Andrea Aime
@geowolf
Technical Lead
Go ahead and kick it, but I think the build server pulls in build.properties from the current git revision, so you will need to use the 2.7.x revision that has this change: e0d32d1c0053b786aba2aa458b3d839634d5d49a
Torben
On Wed, Jul 22, 2015 at 10:29 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jul 22, 2015 at 7:28 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Ah ok… shall I kick it again then?
Ing. Andrea Aime
@geowolf
Technical Lead
I see you already kicked it with the old parameters, so I cancelled your build and re-ran against the new revision. The only change from the previous version is the build.properties file, so this should ostensibly pass cite tests etc.
Torben
On Wed, Jul 22, 2015 at 11:04 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
