[Geoserver-devel] geoserver_release.sh stuck with maven 2 and -T1C
The build box is mostly setup for new version numbers for master, and new build jobs for geoserver-2.5.x
I am however stuck on the geoserver_reelase.sh script used to create 2.5-RC1
The logs #14 show a mvn failure, looks like maven 3 is expected and the script is being provided with maven 2.
maven/java settings:
Apache Maven 2.2.1 (r801777; 2009-08-06 19:16:01+0000)
Java version: 1.6.0_22
Java home: /usr/lib/jvm/java-6-sun-1.6.0.22_x86/jre
…snip…
Unable to parse command line options: Unrecognized option: -T1C
usage: mvn [options] [<goal(s)>] [<phase(s)>]
I am not quite sure what configuration change is needed to run with maven 3, perhaps Justin can provide a hint?
Maven 2 has dropped out of support last week, perhaps it is time to drop it out of our build box.
Jody Garnett
On Fri, Feb 21, 2014 at 5:38 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
build jobs for geoserver-2.5.x<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.5.x/&gt;
I am however stuck on the geoserver_reelase.sh<https://github.com/geoserver/geoserver/blob/2.5.x/build/build_release.sh&gt; script
The logs #14<http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-release/14/console&gt; show
*maven/java settings:*
*Apache Maven 2.2.1 (r801777; 2009-08-06 19:16:01+0000)*
*Java version: 1.6.0_22*
*Java home: /usr/lib/jvm/java-6-sun-1.6.0.22_x86/jre*
*..snip...*
*Unable to parse command line options: Unrecognized option: -T1C*
*usage: mvn [options] [<goal(s)>] [<phase(s)>]*
Maven 2 has <http://maven.40175.n5.nabble.com/RESULT-VOTE-Maven-2-x-is-end-of-life-tt5785220.html&gt;dropped
out of support last week<http://maven.40175.n5.nabble.com/VOTE-Maven-2-x-is-end-of-life-td5784522.html&gt;,
Feel free to remove that -T1C, I added it last time to speed up the round
trips as I was fixing
the scripts for the beta release.
However mind, at the time the release scripts were working with -T1C,
something must
have changed in the maven installation in the meantime
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Afaik nothing on the build server changed with respect to maven install. As for why we use maven 2 it is because of the annoying deployment issues that come with maven 3 and snapshots. So perhaps not an issue for releasing.
On Fri, Feb 21, 2014 at 1:24 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
On Fri, Feb 21, 2014 at 5:38 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
…snip…
Feel free to remove that -T1C, I added it last time to speed up the round trips as I was fixing
However mind, at the time the release scripts were working with -T1C, something must
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
With a bit of help from Andrea I managed to sort this out ( needed to update geoserver_release.sh on master, and then build 2.5.x).
With that in mind release artefacts are available for testing here:
http://ares.boundlessgeo.com/geoserver/release/2.5-RC1/
Jody Garnett
On 21 February 2014 at 3:39:01 pm, Jody Garnett (jody.garnett@anonymised.com) wrote:
…snip…
Jody Garnett
On Sat, Feb 22, 2014 at 1:18 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Gave it a quick spin, seems to work fine :slight_smile:
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, there is a draft blog post as well (if you have a moment).
Jody Garnett
On Sat, Feb 22, 2014 at 10:02 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Feb 22, 2014 at 1:18 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Feb 22, 2014 at 1:32 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Made a couple of minor edits, thanking feature sponsors
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
