Starting the GeoServer release train for 2.24.1 release
Jody Garnett
Jody Garnett
Release artifacts are available for testing: https://build.geoserver.org/view/release/job/geoserver-release/133/artifact/distribution/2.24.1/
Jody Garnett
Jody Garnett
Blog post ready for review: https://github.com/geoserver/geoserver.github.io/pull/170
Jody Garnett
Jody Garnett
Jody Garnett
I tested the bin download locally; but did not hear back from anyone else.
I am going to go ahead with the publish step to allow the docker image to be tested.
The blog post has also recieved a review; merging the PR now; and it should show up as announced on Monday.
Thanks for assistance everyone.
Jody Garnett
Jody Garnett
Jody Garnett
Got an odd error when testing docker 2.24.1:
Loading the spearfish layer preview:
24 Nov 20:40:28 WARN [util.factor] - ClassNotFoundException: org.geotools.data.Repository
java.lang.ClassNotFoundException: org.geotools.data.Repository
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1329)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1141)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:315)
at org.geotools.util.factory.Hints$Key.getValueClass(Hints.java:1425)
at org.geotools.util.factory.Hints$Key.isCompatibleValue(Hints.java:1452)
at org.geotools.util.factory.Hints$ClassKey.isCompatibleValue(Hints.java:1564)
at java.desktop/java.awt.RenderingHints.put(RenderingHints.java:1132)
at java.desktop/java.awt.RenderingHints.putAll(RenderingHints.java:1200)
at org.geotools.referencing.factory.AllAuthoritiesFactory.getHints(AllAuthoritiesFactory.java:130)
at org.geotools.referencing.factory.AllAuthoritiesFactory.getFactories(AllAuthoritiesFactory.java:90)
at org.geotools.referencing.factory.ManyAuthoritiesFactory.getAuthorityFactory(ManyAuthoritiesFactory.java:445)
at org.geotools.referencing.factory.ManyAuthoritiesFactory.getCSAuthorityFactory(ManyAuthoritiesFactory.java:561)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createUnit(AuthorityFactoryAdapter.java:793)
at org.geotools.coverage.grid.io.imageio.geotiff.GeoTiffMetadata2CRSAdapter.createUnit(GeoTiffMetadata2CRSAdapter.java:1591)
at org.geotools.coverage.grid.io.imageio.geotiff.GeoTiffMetadata2CRSAdapter.createProjectedCoordinateReferenceSystem(GeoTiffMetadata2CRSAdapter.java:245)
at org.geotools.coverage.grid.io.imageio.geotiff.GeoTiffMetadata2CRSAdapter.createCoordinateSystem(GeoTiffMetadata2CRSAdapter.java:186)
at org.geotools.gce.geotiff.GeoTiffReader.getHRInfo(GeoTiffReader.java:366)
The Hints does indeed have:
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
At least bin-zip starts on Windows with OpenJDK 11. Layer preview and capabilities are normal.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: perjantai 24. marraskuuta 2023 22.16
Vastaanottaja: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GeoServer release train starting
Jody Garnett
Jody Garnett
Jody Garnett
Confirmed this error also happens with docker and 2.24.0 release.
I have a small PR here to address: https://github.com/geotools/geotools/pull/4561
The functionality is already covered by tests; but we did not pick up on the stack traces I guess.
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Okay I think everything is good now
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
