[Geoserver-devel] GeoServer releases: no more OSX installers?
after a chat on gitter yesterday it seems clear 2.11.5 and 2.13-beta will not have a OSX installer.
The OSX build server that was used to build the installers is gone, and in order to build a signed
installer one needs to get a hold of OSGeo certificate, which requires some procedure and control
to be given out.
So, options coming to mind:
  • We simply drop the installer?
  • Can we use OSGeo funding to get a build server going again? Looks like the are some “reasonably” priced options here: https://portal.macincloud.com/select/#/plans
  • Can we get a volunteer that will build the installer manually every month? Can we go with an unsigned installer, or will we find someone that’s willing and trusted enough to get a hold of the OSGeo certificate?
    Ideas? Anyone interested in volunteering?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
So, this topic has come up before, when the OS X build server was still usable but to be deprecated in “the near future”. We didn’t have too much luck on executing on a good solution then.
My thoughts:
  • Dropping the installer would not be the end of the world, but should still be a last resort. The system independent binary runs fine on OS X (and Java is generally installed by default). If we go this route, we need to be sure to update the install instructions.
  • If we can get some OSGeo funding for a mac build server that definitely seems like the best option.
  • Someone manually building the installers seems like a good way to get a mac installer only on some releases and not on others (due to availability or lack thereof), which almost seems worse from a user perspective then not building the installer at all. I feel like we would want at least two volunteers if we were to seriously consider this option.
    I also have a suggestion for a fourth option:
  • If we are okay with an unsigned installer, I have heard there is a way of spinning up a OS X build box on demand via Travis CI; this might be a easy way of generating the OS X artifacts. I don’t know much more about this, but this looks like it could be another option.
Torben
On Tue, Feb 20, 2018 at 1:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
to be given out.
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
The GeoServer project does have some budget. We could also put in a request to SAC to host a Mac mini for us and provide Jenkins '/ shell access.
On 22 February 2018 at 11:08, Torben Barsballe <tbarsballe@anonymised.com> wrote:
My thoughts:
Torben
Jody Garnett
to be given out.
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.comrge.net
On Fri, Feb 23, 2018 at 7:51 AM, Jody Garnett <jody.garnett@anonymised.com>
access.
A OSGeo hosted mac holding the (precioussss!) OSGeo certificate would seem
like a good match indeed :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
