Hi David,
I am a little concerned about this patch. I don't have a concrete -1 against it but I remember that check handling various cases and an issue arising when I once tried to take it out as well.
Andrea might have a better idea of what that issue actually was. But just a word of caution to proceed carefully.
It might be good for us to add a few more test cases to the dispatcher tests testing some of the more obscure cases. Such as simulating input from a form... or sending both content in the body and parameters as kvp's.
-Justin
dwinslow@anonymised.com wrote:
Revision
10383 <http://fisheye.codehaus.org/changelog/geoserver/?cs=10383>
Author
dwinslow
Date
2008-10-13 17:21:06 -0500 (Mon, 13 Oct 2008)Log Message
Don't use .available() to check whether streams have data in them. Fixes GEOS-2281 <http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-2281> (log filter killing POST requests when body logging enabled)
Modified Paths
* trunk/geoserver/ows/src/main/java/org/geoserver/ows/Dispatcher.java
<#trunkgeoserverowssrcmainjavaorggeoserverowsDispatcherjava>Diff
Modified:
(10382 => 10383)--- trunk/geoserver/ows/src/main/java/org/geoserver/ows/Dispatcher.java 2008-10-13 19:03:31 UTC (rev 10382)
+++ trunk/geoserver/ows/src/main/java/org/geoserver/ows/Dispatcher.java 2008-10-13 22:21:06 UTC (rev 10383)
@@ -223,17 +223,19 @@
//create the kvp map
parseKVP(request);
- if ( !request.get && httpRequest.getInputStream().available() > 0) {
- //wrap the input stream in a buffer input stream
+ if ( !request.get ) { // && httpRequest.getInputStream().available() > 0) {
+ //wrap the input stream in a buffered input stream
request.input = reader(httpRequest);
- //mark the input stream, support up to 2KB, TODO: make this configuratable
+ //mark the input stream, support up to 2KB, TODO: make this configurable
request.input.mark(2048);
if (logger.isLoggable(Level.FINE)) {
char req = new char[1024];
int read = request.input.read(req, 0, 1024);
- if (read < 1024) {
+ if (read == -1) {
+ request.input = null;
+ } else if (read < 1024) {
logger.fine("Raw XML request starts with: " + new String(req));
} else {
logger.fine("Raw XML request starts with: " + new String(req) + "...");------------------------------------------------------------------------
To unsubscribe from this list please visit:
Justin Deoliveira
OpenGeo - http://opengeo.org
