[Geoserver-devel] [geoserver-scm] [15105] trunk/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java: do not force component color model when image is indexed or the Mosaic operation fails due to different sample siz
On Thu, Nov 25, 2010 at 3:53 PM, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao Gabriel,
when you make changes to the rendering chain or to the output format,
I would ask you to discuss that on the ML prior to commit, or at least
to open up a jira.
This has been common practice so far for modules like WFS or main
where just had judge. Given the complexity of the raster direct path
and the fact that
me, daniele and andrea are making it evolve slowly, I would like to
avoid stepping on each other toes.
That said, can you explain what the problem was?
And btw, what's up with the telephone number you added in the commented
out code? :wink:
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
