[Geoserver-devel] Geoserver security improvement proposal
Hi all, I have to write a Master Thesis for my study "Applied IT Security" at the university of Bochum, Germany.
I convinced my mentors to have a topic about security of geodata infrastructures. The title will be something like
"Building a secure GDI using Geoserver,Spring Security,SAML and GeoXACML"
The thesis has 3 main parts.
1) Integration of Spring Security 3.0 into geoserver. This gives us the possibility to offer a lot of authentication mechanisms including customized plugins.
http://static.springsource.org/spring-security/site/docs/3.0.x/reference/introduction.html#what-is-acegi-security
There are also nice possibilities for access control like a new expression syntax.
2) Examine how to integrate the geoxacml community module as spring access plugin into geoserver.
3) Take a deeper look into SAML ( "Single Sign On" would be a nice thing).
The first part has top priority. The existing file based access control system should be refactored to fit into Spring 3.0. No user action should be necessary. I do not want to break existing security deployments.
It is also possible to write the thesis in English. The idea is to have about 60 pages as documentation, the rest of the work is coding/integrating. Since I am not a native English speaker, is there anybody who can read my thesis and correct my mistakes ?
Opinions, Votes ?
Christian
This message was sent using IMP, the Internet Messaging Program.
customized plugins.
expression syntax.
Sounds good (as long as, as you say, it does not break existing
functionality :-p )
However I'm wondering, would this require an upgrade of the whole project to
Spring 3? Did you assess what kind of changes would be needed to do that?
Sounds good as well. Also see the work done by Lennart at:
http://jira.codehaus.org/browse/GEOS-4049
http://jira.codehaus.org/browse/GEOS-4045
Don't know much about this. The SSO I hear people talking about the most is CAS.
deployments.
I can have a look if you give me some time so that I can fit it
into empty spaces in the weekends, but I'm not a native speaker either.
Some actual native speaker would be better: take my offer as a backup plan :slight_smile:
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
About Spring 3.0, taken from Spring Security FAQ
What Java and Spring Framework versions are required?
Spring Security 2.0.x requires a minimum JDK version of 1.4 and is built against Spring 2.0.x. It should also be compatible with applications using Spring 2.5.x.
Spring Security 3.0 requires JDK 1.5 as a minimum and will also require Spring 3.0.
I think, we currently use Spring 2.5.5 ?
A migration guide is here
http://static.springsource.org/spring/docs/upgrade/spring3/html/
I think if we want geoserver security on a professional level, I should study the guide and try to migrate. If you feel that this is a big risk, I have to fall back and use Spring Security 2.0.
And btw, thank you for your backup offer.
Hi Christian, sounds like a very interesting project.
I would be ok with moving to Spring 3.0, may be we can just schedule
that for geoserver 2.2.x. I'm not sure when we'll push for a 2.1 release
but hopefully it won't be that long.
If at all, a minimal assessment of the incompatibilities and an
estimation of the effort required would be very much appreciated.I'll
try to give it a read to the Spring migration guide, but probably moving
to Spring 3 also means migrating the web app from wicket 1.3 to 1.4?
I don't think it's gonna be a small task, but worthwhile one.
Best regards,
Gabriel
require Spring 3.0.
Virtualization is moving to the mainstream and overtaking non-virtualized
environment for deploying applications. Does it make network security
easier or more difficult to achieve? Read this whitepaper to separate the
two and get a better understanding.
http://p.sf.net/sfu/hp-phase2-d2d
Geoserver-devel mailing list
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
As a native English speaker, I’d be willing to provide review of the documentation for grammar etc. I know a bit of computer security terminology (mostly picked up working on Spring Security stuff in GeoServer) but have never really studied it so you may want to keep looking for someone to review for technical accuracy.
David Winslow
OpenGeo - http://opengeo.org/
On Mon, Oct 4, 2010 at 9:37 AM, Gabriel Roldán <groldan@anonymised.com> wrote:
that for geoserver 2.2.x. I’m not sure when we’ll push for a 2.1 release
but hopefully it won’t be that long.
estimation of the effort required would be very much appreciated.I’ll
I don’t think it’s gonna be a small task, but worthwhile one.
Best regards,
Gabriel
require Spring 3.0.
Gabriel Roldan
Since I have no idea about the impact of using Spring 3.0, we could do a smaller step and integrate Spring Security 2.0. This should be possible without taking to much risk. Would be an option, I do not want to wait until next year for Spring 3.0 because I have a time frame (12 month max, starting soon)
Quoting Gabriel Roldán <groldan@anonymised.com>:
Best regards,
Gabriel
require Spring 3.0.
Gabriel Roldan
Hi, I am missing some votes about my proposal to integrate spring security 2.0 as a first smaller step, deferring the migration to 3.0 until the whole geoserver project is migrating to spring 3.0.
In the case of acceptance I would open a jira improvement issue and start working on trunk.
Christian
Hello Christian,
I think no voting at all has been made yet but an general expression of
interest in the work you're about to accomplish. A GSIP would be in
order though:
<http://docs.geoserver.org/latest/en/developer/policies/gsip.html&gt;
Feel free to start your GSIP and use it to explain what needs to be
done, the benefits, the impact on the code base, etc.
It doesn't need to be too much bureaucracy, the idea is to help you move
forward, not to slow you down.
2c.-
Gabriel
Christian
Gabriel Roldan
Aside, please also feel free to start experimenting on the code base as
you see fit. Git is recommended these days as most of us already have
our git branches (on github) where to perform any kind of development
and experimentation, and with the help of git-svn it's easier and
cleaner to commit to the formal svn repo when the time comes.
Best regards,
Gabriel
On Thu, 2010-10-07 at 15:01 -0300, Gabriel Roldán wrote:
Hello Christian,
order though:
2c.-
Gabriel
> Cheers
> Christian
Gabriel Roldan
For those who are interested, I already worked on a patch on revision 14534 on the trunk, to integrate spring-security 2.0.5 which is API compatible with spring-security 3.0.
It's not fully tested but it works for me, but I have no time at the moment to continue. It could be a great thing for geoserver because the GeoserverUserDao could be made compatible with the new interface UserDetailsManager and it could be possible to replace UserDao by custom implementation to introduce other storage support (like JDBC or Ldap which is in use in the georchestra project).
Best regards,
Philippe
Best regards,
Gabriel
Hello Christian,
order though:
2c.-
Gabriel
Christian
Le contenu de ce message n'engage que son auteur et aucunement la soci�t�
DotGEE.
