[Geoserver-devel] geoserver should reload externalGraphic symbols?
I'm styling a point layer with several bitmap symbols. The bitmaps (png) reside on the same server and are referenced in the SLD with a 'file:' url like in:
<ExternalGraphic>
  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:type="simple" xlink:href="file:/var/geoserver/styles/symbols/open_refugee_area.png"/>
  <Format>image/png</Format>
</ExternalGraphic>
I guess geoserver caches these images? Then it does so a bit over-enthousiastic, because when I change these bitmaps on disk, geoserver keeps displaying the old bitmaps, no matter how often I press the 'load' button in the config interface. I would expect it to render the new bitmap instead. Only restarting tomcat helps.
Is there some setting I can adjust to improve this behaviour, or should I change something in my SLD?
Or should I file a jira issue on this?
Vincent.
I used external symbols too some time ago, but honestly I don’t remember exactly about the GeoServer behaviour on handling them.
However, I think is a good idea open up a Jira on this.
On 1/17/07, Vincent Schut <schut@anonymised.com> wrote:
I’m styling a point layer with several bitmap symbols. The bitmaps (png)
reside on the same server and are referenced in the SLD with a ‘file:’
url like in:
image/png
the ‘load’ button in the config interface. I would expect it to render
Vincent.
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
<ExternalGraphic>
</ExternalGraphic>
File a jira issue. It's the ImageLoader class in geotools, that keeps
a static cache of images to be loaded. This improves performance a lot,
but there's no way to flush the cache.
It's not super-easy to fix neither, since the class works against URL,
so it may well load something from the net, not only from the disk where
I can eventually check the last modification date.
<ExternalGraphic>
</ExternalGraphic>
Done: GEOS-856.
Already suspected something like that; tried disabling all options with 'cache' in their wordings but didn't work out... :slight_smile:
Was afraid so. Maybe best and easiest 'fix' is to have geoserver at least refresh the cache when you click the 'load' button from the config web interface?
Vincent.
