[Geoserver-devel] geoserver soft reboot
Can please anyone provide me with a url to trigger the geoserver
catalog/config reload process on a localhost?
Can't extract the request from reload-button in WEB-GUI as it seems to
be capsuled.
I don't want to restart the whole tomcat when new featureTypes get
installed - just reload with a curl request automatically.
Rudi
This one seems to do the job:
http://localhost:8080/geoserver/web/?wicket:interface=:2:reload.catalogConfi
g::IBehaviorListener:0:
Damien
-----Message d'origine-----
De : Hochmeister Rudolf [mailto:rudolf.hochmeister@anonymised.com]
Envoyé : jeudi 16 février 2012 10:52
À : geoserver-devel@lists.sourceforge.net
Objet : [Geoserver-devel] geoserver soft reboot
Can't extract the request from reload-button in WEB-GUI as it seems to be
capsuled.
I don't want to restart the whole tomcat when new featureTypes get installed
Rudi
Virtualization & Cloud Management Using Capacity Planning Cloud computing
makes use of virtualization - but cloud computing also focuses on allowing
computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
Geoserver-devel mailing list
On Thu, Feb 16, 2012 at 10:51 AM, Hochmeister Rudolf <rudolf.hochmeister@anonymised.com> wrote:
Can’t extract the request from reload-button in WEB-GUI as it seems to
be capsuled.
I don’t want to restart the whole tomcat when new featureTypes get
You can use the REST configuration to do that.
Btw, I’m assuming you are adding layers configurations directly on disk
building the xml files by hand? That is not supported, the disk format
can change in time without warnings.
If you use the REST configuration calls instead you can add layers
in a supported way, and you won’t even need to reload the configuration,
as the changes will take effect immediately
See: http://docs.geoserver.org/stable/en/user/restconfig/index.html
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
