[Geoserver-devel] GeoServer stable release tomorrow?
Mark are you still scheduled to release tomorrow? Did you ever get an answer back on cite wfs tests failing?
Jody Garnett
On Tue, Jun 21, 2011 at 11:43 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
just reran cite wfs 1.1 on 2.1.x and I got a full pass.
That said it took 5 minutes to get past the DescribeFeatureType calls, and I don’t know why.
I’ve tried out the slow tests and GeoServer responds to those requests in a blink
of an eye, then cite engine takes forever to decide the response is actually right.
This is one such response:
<xsd:schema xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:gml=“http://www.opengis.net/gml” xmlns:it.geosolutions=“http://www.geo-solutions.it” xmlns:sf=“http://cite.opengeospatial.org/gmlsf” elementFormDefault=“qualified” targetNamespace=“http://cite.opengeospatial.org/gmlsf”>
<xsd:import namespace=“http://www.opengis.net/gml” schemaLocation=“http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd”/>
<xsd:element name=“PrimitiveGeoFeature” substitutionGroup=“gml:_Feature” type=“sf:PrimitiveGeoFeatureType”>
xsd:annotation/
</xsd:element>
<xsd:complexType name=“PrimitiveGeoFeatureType”>
xsd:complexContent
<xsd:extension base=“gml:AbstractFeatureType”>
xsd:sequence
<xsd:element minOccurs=“0” name=“surfaceProperty” type=“gml:SurfacePropertyType”/>
<xsd:element minOccurs=“0” name=“pointProperty” type=“gml:PointPropertyType”/>
<xsd:element minOccurs=“0” name=“curveProperty” type=“gml:CurvePropertyType”/>
<xsd:element name=“intProperty” type=“xsd:integer”/>
<xsd:element minOccurs=“0” name=“uriProperty” type=“xsd:anyURI”/>
<xsd:element name=“measurand” type=“xsd:float”/>
<xsd:element minOccurs=“0” name=“dateTimeProperty” type=“xsd:dateTime”/>
<xsd:element minOccurs=“0” name=“dateProperty” type=“xsd:date”/>
<xsd:element name=“decimalProperty”>
xsd:simpleType
<xsd:restriction base=“xsd:decimal”>
<xsd:totalDigits value=“4”/>
<xsd:fractionDigits value=“2”/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element minOccurs=“0” name=“relatedFeature” type=“gml:ReferenceType”>
xsd:annotation/
</xsd:element>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:schema>
No idea why, Eclipse also takes the same documents and validates it immediately…
Trying to hit the vm running the cite engine during the slow part shows this:
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:129)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:218)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:258)
at java.io.BufferedInputStream.read(BufferedInputStream.java:317)
  • locked <0x00000007e029e548> (a java.io.BufferedInputStream)
    at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:687)
    at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:632)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1195)
  • locked <0x00000007e0294740> (a sun.net.www.protocol.http.HttpURLConnection)
    at org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
    at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
    at org.apache.xerces.impl.xs.opti.SchemaParsingConfig.parse(Unknown Source)
    at org.apache.xerces.impl.xs.opti.SchemaDOMParser.parse(Unknown Source)
    at org.apache.xerces.impl.xs.traversers.XSDHandler.getSchemaDocument(Unknown Source)
    at org.apache.xerces.impl.xs.traversers.XSDHandler.resolveSchema(Unknown Source)
    at org.apache.xerces.impl.xs.traversers.XSDHandler.constructTrees(Unknown Source)
    at org.apache.xerces.impl.xs.traversers.XSDHandler.parseSchema(Unknown Source)
    at org.apache.xerces.impl.xs.XMLSchemaLoader.loadSchema(Unknown Source)
    at org.apache.xerces.impl.xs.XMLSchemaLoader.loadGrammar(Unknown Source)
    at org.apache.xerces.jaxp.validation.XMLSchemaFactory.newSchema(Unknown Source)
    at com.occamlab.te.parsers.XMLValidatingParser.validate(XMLValidatingParser.java:341)
    at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:232)
    at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:167)
So ok, it’s trying to reach out on the net… but for what?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
It seems the source of my confusion is that the build box is running
two sets of cite tests, but both cite-wfs-1.1 and cite-wfs-1.1-trunk
look to be pulling down the current trunk snapshot (as near as I can
tell). So I'm glad to hear it's passing on 2.1, thanks Andrea.
I'll be starting in on the release shortly.
Mark
don't know why.
I've tried out the slow tests and GeoServer responds to those requests in a
blink
right.
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;
xmlns:gml="http://www.opengis.net/gml&quot;
xmlns:it.geosolutions="http://www.geo-solutions.it"
xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot;
elementFormDefault="qualified"
targetNamespace="http://cite.opengeospatial.org/gmlsf&quot;&gt;
<xsd:import namespace="http://www.opengis.net/gml&quot;
schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;/&gt;
<xsd:element name="PrimitiveGeoFeature" substitutionGroup="gml:_Feature"
type="sf:PrimitiveGeoFeatureType">
<xsd:annotation/>
</xsd:element>
<xsd:complexType name="PrimitiveGeoFeatureType">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element minOccurs="0" name="surfaceProperty"
type="gml:SurfacePropertyType"/>
<xsd:element minOccurs="0" name="pointProperty"
type="gml:PointPropertyType"/>
<xsd:element minOccurs="0" name="curveProperty"
type="gml:CurvePropertyType"/>
<xsd:element name="intProperty" type="xsd:integer"/>
<xsd:element minOccurs="0" name="uriProperty" type="xsd:anyURI"/>
<xsd:element name="measurand" type="xsd:float"/>
<xsd:element minOccurs="0" name="dateTimeProperty"
type="xsd:dateTime"/>
<xsd:element minOccurs="0" name="dateProperty" type="xsd:date"/>
<xsd:element name="decimalProperty">
<xsd:simpleType>
<xsd:restriction base="xsd:decimal">
<xsd:totalDigits value="4"/>
<xsd:fractionDigits value="2"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element minOccurs="0" name="relatedFeature"
type="gml:ReferenceType">
<xsd:annotation/>
</xsd:element>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
immediately...
this:
- locked <0x00000007e029e548> (a java.io.BufferedInputStream)
at
- locked <0x00000007e0294740> (a
at
at
Source)
Source)
Source)
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
Source)
at
at
at
at
So ok, it's trying to reach out on the net... but for what?
Ing. Andrea Aime
Tech lead
EditLive Enterprise is the world's most technically advanced content
authoring tool. Experience the power of Track Changes, Inline Image
Editing and ensure content is compliant with Accessibility Checking.
http://p.sf.net/sfu/ephox-dev2dev
Geoserver-devel mailing list
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
On Wed, Jun 22, 2011 at 12:59 AM, Mark Leslie <mrk.leslie@anonymised.com03…> wrote:
tell). So I’m glad to hear it’s passing on 2.1, thanks Andrea.
Where do you see that? The very start of a run on cite-wfs-1.1 shows:
Started by timer
[cite] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson3143085910779845230.sh
+ ./run.sh wfs-1.1.0 2.1.x
Archive:  /var/www/html/geoserver/2.1.x/geoserver-2.1.x-latest-bin.zip
   creating: geoserver/geoserver-2.1-SNAPSHOT/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/openlayers/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/openlayers/img/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/openlayers/theme/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/openlayers/theme/default/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/openlayers/theme/default/img/
   creating: geoserver/geoserver-2.1-SNAPSHOT/webapps/geoserver/schemas/
version = 2.1-SNAPSHOT
svn revision = 16072
build date = 22-Jun-2011 05:02
geotools version = 2.7-SNAPSHOT
geotools revision = 37471
hudson build = -1
Ing. Andrea Aime
Tech lead
On 22 June 2011 16:33, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jun 22, 2011 at 12:59 AM, Mark Leslie <mrk.leslie@anonymised.com> wrote:
Started by timer
creating:
creating:
creating:
creating:
hudson build = -1
Whoops, missed the reply-all.
I see that as well in the console (now that I look), but looking at
the workspace shows 'geoserver/geoserver-2.2-SNAPSHOT' instead.
Mark Leslie
LISAsoft
My thought is referenced schemas for validation. For instance since describe feature types pull in gml schemas, and those schemas are written to reference schemas from schemas.opengis.net, and the like. And also for things like the xml schema itself which downloads:
http://www.w3.org/2001/xml.xsd
This is the one i figured there was a problem with because the errors were complaining about xml:lang not being defined, and it is defined in that schema. So i tested a download of it from the build server and indeed the connection would time out. Maybe if we move the tests to a different server they will be happy… i will try to talk to our sysadmin about that.
On Tue, Jun 21, 2011 at 2:00 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
xsd:annotation/
</xsd:element>
xsd:complexContent
xsd:sequence
xsd:simpleType
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
xsd:annotation/
</xsd:element>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
Ing. Andrea Aime
Tech lead
EditLive Enterprise is the world’s most technically advanced content
Justin Deoliveira
OpenGeo - http://opengeo.org
On Wed, Jun 22, 2011 at 5:19 PM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
Yeah, that’s likely the slowness cause here too. Trying to reach for that url is excruciatingly slow, which I guess accounts
for the slow times. Wondering… would it be any better if we bundled that schema in GeoServer as well,
and link to it in the DescribeFeatureType schema locations?
Ing. Andrea Aime
Tech lead
This is why gt-app-schema-resolver exists: to ensure that app-schema-test validation tests never touch the network (schemas are in jars).
Can the CITE teamengine be configured to use an OASIS catalog?
This is the one i figured there was a problem with because the errors were complaining about xml:lang not being defined, and it is defined in that schema. So i tested a download of it from the build server and indeed the connection would time out. Maybe if we move the tests to a different server they will be happy... i will try to talk to our sysadmin about that.
On Tue, Jun 21, 2011 at 2:00 PM, Andrea Aime<andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>> wrote:
On Tue, Jun 21, 2011 at 11:43 AM, Jody Garnett<jody.garnett@anonymised.com<mailto:jody.garnett@anonymised.com>> wrote:
That said it took 5 minutes to get past the DescribeFeatureType calls, and I don't know why.
I've tried out the slow tests and GeoServer responds to those requests in a blink
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:it.geosolutions="http://www.geo-solutions.it" xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot; elementFormDefault="qualified" targetNamespace="http://cite.opengeospatial.org/gmlsf&quot;&gt;
   <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;/&gt;
   <xsd:element name="PrimitiveGeoFeature" substitutionGroup="gml:_Feature" type="sf:PrimitiveGeoFeatureType">
     <xsd:annotation/>
   </xsd:element>
         <xsd:sequence>
           <xsd:element minOccurs="0" name="surfaceProperty" type="gml:SurfacePropertyType"/>
           <xsd:element minOccurs="0" name="pointProperty" type="gml:PointPropertyType"/>
           <xsd:element minOccurs="0" name="curveProperty" type="gml:CurvePropertyType"/>
           <xsd:element minOccurs="0" name="dateTimeProperty" type="xsd:dateTime"/>
             <xsd:simpleType>
               </xsd:restriction>
             </xsd:simpleType>
           </xsd:element>
           <xsd:element minOccurs="0" name="relatedFeature" type="gml:ReferenceType">
             <xsd:annotation/>
           </xsd:element>
         </xsd:sequence>
       </xsd:extension>
   </xsd:complexType>
</xsd:schema>
No idea why, Eclipse also takes the same documents and validates it immediately...
         - locked<0x00000007e029e548> (a java.io.BufferedInputStream)
         - locked<0x00000007e0294740> (a sun.net.www.protocol.http.HttpURLConnection)
Ing. Andrea Aime
Tech lead
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@lists.sourceforge.net>
Justin Deoliveira
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Not that I know of… maybe though, i have never quite looked into it that deep. What does this generally look like? Is it some property that can be set at a higher level that is respected by the low level xml parsers? Or is it something the application has to configure?
On Wed, Jun 22, 2011 at 7:37 PM, Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com wrote:
On Tue, Jun 21, 2011 at 2:00 PM, Andrea Aime<andrea.aime@anonymised.comsolutions.itmailto:[andrea.aime@anonymised.com](mailto:andrea.aime@anonymised.com)> wrote:
On Tue, Jun 21, 2011 at 11:43 AM, Jody Garnett<jody.garnett@anonymised.commailto:[jody.garnett@anonymised.com](mailto:jody.garnett@anonymised.com)> wrote:
xsd:annotation/
</xsd:element>
xsd:complexContent
xsd:sequence
xsd:simpleType
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
xsd:annotation/
</xsd:element>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
  • locked<0x00000007e029e548> (a java.io.BufferedInputStream)
  • locked<0x00000007e0294740> (a sun.net.www.protocol.http.HttpURLConnection)
Ing. Andrea Aime
Tech lead
Geoserver-devel@anonymised.comsourceforge.netmailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Justin Deoliveira
Justin Deoliveira
