[Geoserver-devel] geoserver tests and internet connection
Is there a rule about whether geoserver unit/integration tests should be able to run without internet connection? Couldn't find anything, but it seems that most are with only a few exceptions: one method in CSW and a number of fairly recent WCS tests.. Because of those few exceptions you can't build geoserver without internet, unless you turn unit tests off. This could be a problem for some building servers that disallow remote access.
In all cases the problem seems to be related to the downloading of XSD schemes. The problem should be able to be resolved by either including the right XSD's somewhere in the classpath (well, in the right place, eh), or just remove the references to them in the XML files. I already did this for the CSW test: https://github.com/geoserver/geoserver/pull/3414
Kind Regards
Niels
No written rule, but the practice is to mark a test that needs to talk to a server
(remote or local, does not matter) or fetch a remote file as an OnlineTest.
However sometimes a test accesses the internet without the developer even being
aware of it, and they are hard to spot because it’s uncommon to do a build in a fully
isolated environment (happens to me when I try to hack on a plane, but that’s pretty much it,
and have to prepare the machine in advance to make sure maven already has all
the jars it needs).
Couldn’t find anything, but it
number of fairly recent WCS tests…
Do you have a list?
can’t build geoserver without internet, unless you turn unit tests off.
access.
For the case of a build server, maven itself needs internet access, e.g, to get artifacts when version change, or
when a new dependency is added.
Unless you’re thinking about a situation where there is also a dedicated and accessible repository manager,
which can access the internet on behalf of maven.
I guess it could be useful to have a build checking if the code can be built without
internet connection, guessing it would first need an online pass making maven load
everything it needs, and then disconnect the network and run the tests.
Not sure if feasible though (thinking about Travis for example).
the right XSD’s somewhere in the classpath (well, in the right place,
Yes, this is the common way to do fix that problem.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On 13/05/2019 11:47, Andrea Aime wrote:
Do you have a list?
Apart from the CSW one from the PR, these WCS2 ones:
testDescribeWithTimeElevation(org.geoserver.wcs2_0.ResourceAccessManagerWCSTest): Could not parse the WCS 2.0 schemas
gridCellCenterEnforce(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultiBandKVPNoWs(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultiBandKVP(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testBasicKVP(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeTimeContinousInterval(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testCustomNullValue(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeCustomDimensionsList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultipleCoveragesNoWs(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeTimeElevationList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testAxisOrderUtm(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeTimeList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMetadata(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testProjectectedKVP(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeTimeRangeList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeElevationRangeList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeElevationContinuousInterval(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeElevationValuesList(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultipleCoveragesLocalWs(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testCustomUnit(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultipleCoverages(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testMultiBandKVPLocalWs(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeTimeDiscreteInterval(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeElevationDiscreteInterval(org.geoserver.wcs2_0.kvp.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testBasicKVP(org.geoserver.wcs2_0.kvp.GetCapabilitiesTest): Could not parse the WCS 2.0 schemas
testMetadata(org.geoserver.wcs2_0.kvp.GetCapabilitiesTest): Could not parse the WCS 2.0 schemas
testDescribeCoverageSimple(org.geoserver.wcs2_0.xml.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testDescribeCoverageMultiband(org.geoserver.wcs2_0.xml.DescribeCoverageTest): Could not parse the WCS 2.0 schemas
testBasicPost(org.geoserver.wcs2_0.xml.GetCapabilitiesTest): Could not parse the WCS 2.0 schemas
Unless you're thinking about a situation where there is also a dedicated and accessible repository manager,
This is the situation I am dealing with.
Applications are built on a bamboo server with dedicated and accessible repository manager, but no internet access for tests.
Regards
Niels
I can confirm the failure… but don’t understand the " a number of fairly recent WCS tests" statement.
The tests have been around for years now, do you mean they started failing recently? If so, do you have a date and potential
commit candidates that introduced the network dependency?
As far as I can see the code is failing to get to the GML schemas (which WCS schemas do reference).
I see. It’s an uncommon setup, but the issue is legit (if probably low priority). I’d start by opening a ticket.
On 13/05/2019 14:38, Andrea Aime wrote:
I can confirm the failure... but don't understand the " a number of fairly recent WCS tests" statement.
Indeed, that was incorrect. The tests were there but didn't fail in version 2.12. Just tested and they do fail in 2.13. Something must have changed in between those two versions, but I haven't narrowed it further down (yet).
I see. It's an uncommon setup, but the issue is legit (if probably low priority). I'd start by opening a ticket.
ok. Once I have some spare time, I might investigate further myself and propose a solution.
Regards
Niels
Awesome, thanks for the ticket and for having a look (when you have time, of course)
