[Geoserver-devel] GeoServer to Geotools Capabilities Interaction
I know many of you work on Geotools as well as GeoServer, so I thought I might ask what the best route is to report an issue with org.geotoosl.filter.Capabilities.java (10.4, gt-main).
I am building my own datastore to interact with a common data framework within the company. While I was adding support for the Simple_Comparisions from the Capabilities, I was a little surprised when my testing for PropertyLessThanOrEqual didn’t stop at my breakpoint. I went into the Capabilities and noticed this:
public static Capabilities SIMPLE_COMPARISONS;
static {
SIMPLE_COMPARISONS = new Capabilities();
SIMPLE_COMPARISONS.addType( PropertyIsEqualTo.class ); //COMPARE_EQUALS|
SIMPLE_COMPARISONS.addType( PropertyIsGreaterThan.class ); // COMPARE_GREATER_THAN
SIMPLE_COMPARISONS.addType( PropertyIsGreaterThanOrEqualTo.class ); // COMPARE_GREATER_THAN_EQUAL
SIMPLE_COMPARISONS.addType( PropertyIsLessThan.class ); // COMPARE_LESS_THAN
SIMPLE_COMPARISONS.addType( PropertyIsGreaterThanOrEqualTo.class ); // COMPARE_LESS_THAN_EQUAL
SIMPLE_COMPARISONS.addType( PropertyIsNotEqualTo.class ); // COMPARE_NOT_EQUALS;
What is the best way to report this issue?
(for mail clients that don’t support rich text/html body, the PropertyIsGreaterThanOrEqualTo is listed 2 times in the list with different comments)
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@anonymised.com
GeoTools issue tracker is the first stop - preferable with patch+test
Followed by email discussion on geotools-devel if necessary.
(attachments)
Jody Garnett
On Tue, Apr 1, 2014 at 6:11 AM, Chris Snider <chris.snider@anonymised.com> wrote:
static {
Chris Snider
Geoserver-devel mailing list
