Dear list,
it looks like Travis is failing on importer-core module due to this issue
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-importer-core: Compilation failure
**[ERROR] error: error reading /home/travis/.m2/repository/org/apache/commons/commons-vfs2/2.0/commons-vfs2-2.0.jar; /home/travis/.m2/repository/org/apache/commons/commons-vfs2/2.0/commons-vfs2-2.0.jar (Permission denied)**
[ERROR] -> [Help 1]
Does anyone have access to the Travis server in order to fix this?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
