[Geoserver-devel] geoserver-trunk Build Failed
View results here -> http://geo.openplans.org:9090/buildresults/geoserver-trunk?log=log20061005120105
my bad
Brent Owens
(The Open Planning Project)
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
Build still appears to be down, KMLWriter test is failing.
Note: The cruise control build will also report when the build has been
fixed after being broken, so if another message doesn't appear saying
"build Fixed" after attempting to fix a broken build, it is still broken.
However, the cruise control log and test results page doesn't really say
what tests fail. I will have to work on that.
-Justin
Brent Owens wrote:
my bad
Brent Owens
!DSPAM:1004,45253d72312141460912952!
Justin Deoliveira
I removed the test so it should work now.
I will try and improve it so that it doesn't break. I think it is the files it is looking for that is breaking it.
Brent Owens
-Justin
Brent Owens wrote:
my bad
Brent Owens
I still don't think it is fixed. The test case now has no methods, which
is an illegal test. I would rather just remove the test if it is not
being run, or fix it.
-Justin
Brent Owens
-Justin
Brent Owens wrote:
my bad
Brent Owens
!DSPAM:1004,452678ab133638365517736!
Justin Deoliveira
damn :stuck_out_tongue:
I will try again.
sorry about that.
Brent Owens
-Justin
Brent Owens
-Justin
Brent Owens wrote:
my bad
Brent Owens
