[Geoserver-devel] geoserver-trunk Build Failed
View results here -> http://geo.openplans.org:9090/buildresults/geoserver-trunk?log=log20061103172716
You can ignore this, it is failing because it is running the http tests
due to the fact that there is a geoserver running on geo. If no one
objects i would like to create a profile for the http tests so that they
arent normally run.
-Justin
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,454bc383235916309890654!
Justin Deoliveira
The Open Planning Project
ok cool.
Brent Owens
(The Open Planning Project)
arent normally run.
-Justin
arent normally run.
Go for it :slight_smile:
