[Geoserver-devel] GeoServer unable to compute intersection when unit of longitudes are in different format
Is this update you mention for WCS 2.0 specifically for the case where bounding boxes cross the dateline, or is it more general to the situation of bounding boxes being specified with longitude ranges [0:360] instead of [-180:180] such as GRIB2 data?
On Fri, Aug 29, 2014 at 4:55 PM, Benz, David E <David.Benz@anonymised.com> wrote:
It is the for the case of dateline crossing, and it supports what the WCS
standard traditionally
suggested, that is, to use specify a minx > maxx, but it will work also for
cases in which you
go beyond 180 (but are still crossing the dateline).
I'm not sure however what might happen if you ask for an area that's fully
beyond 180,
the sponsoring for dateline crossing in WCS did not cover this case.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
