[Geoserver-devel] [Geoserver-users] 1. Re: HTTP ERROR: 503 (Justin Deoliveira)
Hi Tom,
(can you keep your replies on the public list :)).
Thanks for sending the log, there is a problem occurring on startup that is preventing geoserver from starting properly. It seems to be related to the internal EPSG database. Can you perform the following steps:
1. Shut down GeoServer
2. Remove the directory
C:\Documents and Settings\<USER>\Local Settings\Temp\Geotools
/tmp/Geotools (on linux)
3. Start GeoServer again
Hopefully that does it, i have seen this issue come up before and this was the solution.
-Justin
Tomas Lopes wrote:
Here is the log from latest attempt if it helps.
Tom
On Thu, Aug 14, 2008 at 7:03 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Hi Tom,
    Hmmm... quite strange. My only thought would be that perhaps oracle
    or some other service is running on port 8080. The reason i say that
    is because i have never seen GeoServer give back a 503 before.
    Can you try changing the port GeoServer is running on, and see if
    you get a 503 in a different port. There are instructions on how to
    do this here:
    http://geoserver.org/pages/viewpage.action?pageId=1278052
    Change it to something like 9090 and then try accessing it from
    there. Let us know how it goes or if you have problems changing the
    port.
    -Justin
    Tomas Lopes wrote:
        Hello Justin,
        Thank you for the reply. I have installed GeoServer straight
        from the .exe that i downloaded. At first, my 8080 port was
        being used by my Oracle TNSlistener. I didnt want GeoServer to
        run on any other port than 8080 so I blew out my instance of
        oracle and will reinstall when I get this geoserver prob solved.
         Solved that prob and then unistalled and reinstalled the
        geoserver .exe. Started up the service, ran fine on port 8080.
         Its just when I go to administrator site that I get the 503
        error. Oh, and I am accessing it through
        http://localhost:8080/geoserver/welcome
        <http://localhost:8080/geoserver/welcome.do&gt;
        Any other ideas?
        Thanks ahead of time,
        Tom
        This SF.Net email is sponsored by the Moblin Your Move
        Developer's challenge
        Build the coolest Linux based applications with Moblin SDK & win
        great prizes
        Grand prize is a trip for two to an Open Source event anywhere
        in the world
        http://moblin-contest.org/redirect.php?banner_id=100&url=/
        <http://moblin-contest.org/redirect.php?banner_id=100&url=/&gt;
        Geoserver-users mailing list
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Justin Deoliveira
    Software Engineer, OpenGeo
    http://opengeo.org
Justin Deoliveira
http://opengeo.org
