[Geoserver-devel] [Geoserver-users] DescribeFeatureType problem
The problem with the encoding param value is in (but in multiple places as
far as I can tell):
main\java\org\geoserver\wfs\xml\v1_0_0\XmlSchemaEncoder.java
tempResponse.append("<?xml version=\"1.0\" encoding=\"" +
wfs.getCharSet().displayName()
            + "\"?>" + "\n<xs:schema ");
Is this not the same as:
http://jira.codehaus.org/browse/GEOS-693
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Gabriel Roldán <groldan@anonymised.com>
Naar: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Cc: Andrea Aime <aaime@anonymised.com>, Saul Farber
<Saul.Farber@anonymised.com>, 'Geoserver-devel'
<geoserver-devel@lists.sourceforge.net>
Onderwerp: Re: [Geoserver-users] DescribeFeatureType problem
Datum: 23/01/08 11:59
Hi Bart,
cc'ing geoserver-devel.
Glad it worked, I've tracked it at
&lt;http://jira.codehaus.org/browse/GEOT-1687&gt;
Regarding the encoding declaration problem I'm not sure, does someone know
if
its a known problem? Otherwise please add a jira issue for it.
cheers,
Gabriel
On Wednesday 23 January 2008 02:39:49 pm Bart van den Eijnden (OSGIS)
wrote:
&gt; Hi Gabriel,
&gt;
&gt; this works, it leaves out the column.
&gt;
&gt; Now I also get the 1.0.0 response for DescribeFeatureType, but there
is the
&gt; old problem with the encoding of the xml tag (encoding=&quot;UTF-8:
Unicode
&gt; UTF-8&quot; instead of encoding=&quot;UTF-8&quot;).
&gt;
&gt; &lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8: Unicode
UTF-8&quot;?&gt;&lt;xs:schema
&gt; targetNamespace=&quot;http://www.minvenw.nl/rws/agi&quot;
&gt; xmlns:rwsagi=&quot;http://www.minvenw.nl/rws/agi&quot;
&gt; xmlns:gml=&quot;http://www.opengis.net/gml&quot;
&gt; xmlns:xs=&quot;http://www.w3.org/2001/XMLSchema&quot;
elementFormDefault=&quot;qualified&quot;
&gt; attributeFormDefault=&quot;unqualified&quot;
version=&quot;1.0&quot;&gt;&lt;xs:import
&gt; namespace=&quot;http://www.opengis.net/gml&quot;
&gt;
schemaLocation=&quot;http://145.50.148.45:8082/geoserver/schemas/gml/2.1.2.1/fea
&gt;ture.xsd&quot;/&gt;&lt;xs:complexType
&gt; xmlns=&quot;http://www.w3.org/2001/XMLSchema&quot;
&gt;
name=&quot;DID.ANNOTATIE_Type&quot;&gt;&lt;xs:complexContent&gt;&lt;xs:extension
&gt;
base=&quot;gml:AbstractFeatureType&quot;&gt;&lt;xs:sequence&gt;&lt;xs:element
name=&quot;OBJECTID&quot;
&gt; minOccurs=&quot;0&quot; nillable=&quot;true&quot;
type=&quot;xs:int&quot;/&gt;&lt;xs:element name=&quot;DATUM&quot;
type=&quot;xs:dateTime&quot;/&gt;&lt;xs:element
&gt; name=&quot;GEBRUIKER&quot; minOccurs=&quot;0&quot;
&gt; nillable=&quot;true&quot;&gt;&lt;xs:simpleType&gt;&lt;xs:restriction
&gt; base=&quot;xs:string&quot;&gt;&lt;xs:maxLength
&gt;
value=&quot;2147483647&quot;/&gt;&lt;/xs:restriction&gt;&lt;/xs:simpleType&gt;&lt;/xs:element&gt;&lt;xs:eleme
&gt;nt name=&quot;TITEL&quot; minOccurs=&quot;0&quot;
&gt;
&gt;nt name=&quot;SHAPE&quot; minOccurs=&quot;0&quot;
&gt;
type=&quot;gml:MultiPolygonPropertyType&quot;/&gt;&lt;/xs:sequence&gt;&lt;/xs:extension&gt;&lt;/xs:comp
&gt;lexContent&gt;&lt;/xs:complexType&gt;&lt;xs:element
name=&quot;DID.ANNOTATIE&quot;
&gt; type=&quot;rwsagi:DID.ANNOTATIE_Type&quot;
&gt; substitutionGroup=&quot;gml:_Feature&quot;/&gt;&lt;/xs:schema&gt;
&gt;
&gt; Best regards,
&gt; Bart
&gt;
&gt; --
&gt; Bart van den Eijnden
&gt; OSGIS, Open Source GIS
&gt; http://www.osgis.nl
&gt;
&gt;
&gt; --------- Oorspronkelijk bericht --------
&gt; Van: Gabriel Roldán &lt;groldan@anonymised.com&gt;
&gt; Naar: Bart van den Eijnden OSGIS &lt;bartvde@anonymised.com&gt;
&gt; Onderwerp: Re: [Geoserver-users] DescribeFeatureType problem
&gt; Datum: 23/01/08 10:06
&gt;
&gt; &gt; Hey Bart,
&gt; &gt; cool so.
&gt; &gt; Please try out the attached jar.
&gt; &gt; It _should_ avoid setting up a attribute types that can't be
handled
&gt;
&gt; (blob,
&gt;
&gt; &gt; raster) into feature types.
&gt; &gt; Note I don't have a way to test it right now, so you'll be my
lab rabbit.
&gt; &gt;
&gt; &gt; Please let me know how it goes. It would be good if you set the
geoserver
&gt; &gt; logging level to GEOTOOLS_DEVELOPER profile so the log contains
as much
&gt; &gt; information as possible, and upon any error send me the
geoserver log.
&gt; &gt;
&gt; &gt; Thanks in advance.
&gt; &gt;
&gt; &gt; Gabriel
&gt; &gt;
&gt; &gt; On Wednesday 23 January 2008 12:05:22 pm Bart van den Eijnden
(OSGIS)
&gt;
&gt; wrote:
&gt; &gt; &amp;gt; Hi Gabriel,
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; the attribute is nillable, and I don't need to put
anything in it.
&gt;
&gt; It's
&gt;
&gt; &gt; &amp;gt; just that ArcSDE tells me not to remove this column
otherwise I
&gt; &gt; would
&gt;
&gt; have
&gt;
&gt; &gt; &amp;gt; done that :slight_smile:
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; I would be willing to try a jar out ofcourse. TIA.
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; Best regards,
&gt; &gt; &amp;gt; Bart
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; --
&gt; &gt; &amp;gt; Bart van den Eijnden
&gt; &gt; &amp;gt; OSGIS, Open Source GIS
&gt; &gt; &amp;gt; http://www.osgis.nl
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; --------- Oorspronkelijk bericht --------
&gt; &gt; &amp;gt; Van: Gabriel Roldán
&amp;lt;groldan@anonymised.com&amp;gt;
&gt; &gt; &amp;gt; Naar: geoserver-users@lists.sourceforge.net
&gt; &gt; &amp;gt; &amp;lt;geoserver-users@lists.sourceforge.net&amp;gt;
&gt; &gt; &amp;gt; Cc: Andrea Aime &amp;lt;aaime@anonymised.com&amp;gt;,
&gt;
&gt; OSGIS
&gt;
&gt; &gt; &amp;gt; &amp;lt;bartvde@anonymised.com&amp;gt;, Saul Farber
&gt; &gt; &amp;lt;Saul.Farber@anonymised.com&amp;gt; &amp;gt; Onderwerp: Re:
[Geoserver-users]
&gt; &gt; DescribeFeatureType problem &amp;gt; Datum: 23/01/08 08:53
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; Hi Bart, sorry for the late response
&gt; &gt; &amp;gt; &amp;gt; the best I can think of to enable you using
the table is to try
&gt;
&gt; a
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; workaround
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; like ignoring this kind of columns in the
geotools arcsde
&gt; &gt; plugin
&gt;
&gt; as long
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; as
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; they're nillable.
&gt; &gt; &amp;gt; &amp;gt; I could try that and send you a jar to try
out. You don't need
&gt;
&gt; to set a
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; value
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; for that column through WFS-T, right? if so
would ignoring that
&gt;
&gt; column
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; would
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; be enough for your needs?
&gt; &gt; &amp;gt; &amp;gt; Otherwise we should need to actually support
blobs at arcsde
&gt;
&gt; (which is
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; there
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; but never actually tried it), and which could
be more
&gt;
&gt; complicated, on the
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; WFS
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; side of the fence. That won't happen in the
very near future
&gt;
&gt; though
&gt;
&gt; &gt; &amp;gt; &amp;gt; except
&gt; &gt; &amp;gt; &amp;gt; through some funded work or code donation, due
to other higher
&gt;
&gt; priority
&gt;
&gt; &gt; &amp;gt; &amp;gt; concerns.
&gt; &gt; &amp;gt; &amp;gt; Would you be willing to try out an arcsde jar
with that
&gt;
&gt; workaround so?
&gt;
&gt; &gt; &amp;gt; &amp;gt; Cheers,
&gt; &gt; &amp;gt; &amp;gt; Gabriel
&gt; &gt; &amp;gt; &amp;gt; On Wednesday 23 January 2008 10:19:51 am
Andrea Aime wrote:
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; Bart van den Eijnden (OSGIS) ha
scritto:
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; &amp;amp;gt; Hi Andrea,
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; &amp;amp;gt; the table is still
empty, we are trying to
&gt; &gt; use
&gt;
&gt; WFS-T to fill it
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; but
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; &amp;amp;gt; without success
right now. So I can't do a
&gt;
&gt; GetFeature as yet
&gt;
&gt; &gt; &amp;gt; &amp;gt; :slight_smile: &amp;amp;gt; &amp;amp;gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; &amp;amp;gt; For reference:
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt;
&gt;
&gt;
http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleSh
&gt;
&gt; &gt; &amp;gt;
&amp;amp;gt;ow&amp;amp;amp;d=21938
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; Hum, not sure we could do
anything good with this kind
&gt;
&gt; of
&gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; column... maybe it would be wiser
to hide it at the
&gt;
&gt; datastore
&gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; level? Doing WFS-T on it may be
problematic thought,
&gt; &gt; is
&gt;
&gt; ArcSDE
&gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; able to fill in a default value
if we don't provide
&gt;
&gt; one?
&gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; ArcSDE gurus needed here.
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; Cheers
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; Andrea
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt;
&gt;
&gt;
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; This SF.net email is sponsored
by: Microsoft
&gt; &gt; &amp;gt; &amp;gt; &amp;amp;gt; Defy all challenges. Microsoft(R)
Visual Studio 2008.
&gt; &gt; http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ &amp;gt;
&amp;gt;
&gt; &gt; &amp;amp;gt; _______________________________________________
&amp;gt; &amp;gt;
&gt; &gt; &amp;amp;gt; Geoserver-users mailing list
&gt;
&gt; https://lists.sourceforge.net/lists/listinfo/geoserver-users
&gt;
&gt; &gt; &amp;gt;
&gt; &gt; &amp;gt;
&gt;
&gt; !DSPAM:4045,479743c931291096210785!
far as I can tell):
Ah yes, but in a different place. Can you open a jira
issue for that?
So you're running in Websphere too? I cannot seem to reproduce
the issue using Sun jdk and Tomcat.
Thanks Bart,
yes, it seems to be exactly the same problem.
Yet, I can see the wrong code in XmlSchemaEncoder and it seems the problem
showing up or not depends on the JVM in use.
Just created <http://jira.codehaus.org/browse/GEOS-1705&gt;
Gonna fix it asap.
Gabriel
far as I can tell):
Best regards,
Bart
http://www.osgis.nl
> Hi Bart,
> know
if
> cheers,
> Gabriel
wrote:
> &gt; Hi Gabriel,
> &gt;
> &gt;
is the
Unicode
> &gt;
> &gt;
1/fea
> &gt;
nsion
> &gt;
nt name=&quot;OBJECTID&quot;
> &gt;
> &gt;
> &gt;
> &gt;
> &gt; Best regards,
> &gt; Bart
> &gt;
> &gt; --
> &gt;
> &gt;
> &gt;
> &gt; &gt; Hey Bart,
> &gt; &gt; cool so.
handled
> &gt;
> &gt; (blob,
> &gt;
lab rabbit.
> &gt; &gt;
geoserver
as much
geoserver log.
> &gt; &gt;
> &gt; &gt;
> &gt; &gt; Gabriel
> &gt; &gt;
(OSGIS)
> &gt;
> &gt; &gt; &amp;gt;
anything in it.
> &gt;
> &gt; It's
> &gt;
otherwise I
> &gt; &gt; would
> &gt;
> &gt; have
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt; OSGIS
> &gt;
[Geoserver-users]
> &gt; &gt; &amp;gt;
the table is to try
> &gt;
> &gt; a
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
geotools arcsde
> &gt; &gt; plugin
> &gt;
> &gt; as long
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
out. You don't need
> &gt;
> &gt; to set a
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
would ignoring that
> &gt;
> &gt; column
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
blobs at arcsde
> &gt;
> &gt; (which is
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
be more
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
very near future
> &gt;
> &gt; though
> &gt;
> due
to other higher
> &gt;
> &gt; priority
> &gt;
with that
> &gt;
> &gt; workaround so?
> &gt;
scritto:
> &gt; &gt; use
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt; of
> &gt;
> wiser
to hide it at the
> &gt;
> &gt; datastore
> &gt;
> &gt; &gt; is
> &gt;
> &gt; ArcSDE
> &gt;
if we don't provide
> &gt;
> &gt; one?
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
by: Microsoft
> Microsoft(R)
Visual Studio 2008.
> &amp;gt;
&amp;gt;
&amp;gt; &amp;gt;
> &gt;
> &gt;
> &gt; &gt; &amp;gt;
> &gt; &gt; &amp;gt;
> &gt;
> &gt;
!DSPAM:4045,47975f6885342092453641!
