We use IBM java which must be the culprit then
java-1.4.2-ibm which is default on Red Hat Enterprise 3.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Andrea Aime <aaime@anonymised.com>
Naar: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Cc: Gabriel Roldán <groldan@anonymised.com>, 'Geoserver-devel'
<geoserver-devel@lists.sourceforge.net>, Saul Farber
<Saul.Farber@anonymised.com>
Onderwerp: Re: [Geoserver-devel] [Geoserver-users] DescribeFeatureType
problem
Datum: 23/01/08 13:52
Bart van den Eijnden (OSGIS) ha scritto:
> The problem with the encoding param value is in (but in multiple
places as
> far as I can tell):
> mainjavaorggeoserverwfsxmlv1_0_0XmlSchemaEncoder.java
> tempResponse.append("<?xml version="1.0"
encoding="" +
> wfs.getCharSet().displayName()
> + ""?>" + "n<xs:schema ");
> Is this not the same as:
> http://jira.codehaus.org/browse/GEOS-693Ah yes, but in a different place. Can you open a jira
issue for that?So you're running in Websphere too? I cannot seem to reproduce
the issue using Sun jdk and Tomcat.Cheers
