Hi Ruben,
I am getting the same issue as you. I am trying out the new Geoserver
2.2 with a
content.ftl and my WEB-INF/lib is using freemarker-2.3.18.jar
<#list features as feature> works fine but these don't work anymore
(used to be OK
with Geoserver 2.1.1):-
<#assign size = features?size>
and
<#assign x = features[0].LOCATION.value>
fail with Java exception:
java.io.IOException: Error occured processing content template
content.ftl for org.geoserver.wms.MapLayerInfo@anonymised.com Error occured
processing content template content.ftl for
org.geoserver.wms.MapLayerInfo@anonymised.com Expected number, sequence, or
string. features evaluated instead to
org.geoserver.template.DirectTemplateFeatureCollectionFactory$TemplateFeatureCollection
on line 18, column 14 in content.ftl.
See also my other post at:
http://osgeo-org.1560.n6.nabble.com/Freemarker-Template-Error-Geoserver-2-2-td5014712.html
Did you solve this problem?
Andrew
On 9/24/12, Rubén Illana <rig.icm@anonymised.com> wrote:
Hi everyone,
we are updating our deploys to new Geoserver 2.2 and we are having some
issues with FTL files and GetfeatureInfo requests.The java exception we get is:
*java.io.IOException: Error occured processing content template content.ftl
for org.geoserver.wms.MapLayerInfo@anonymised.com Error occured processing
org.geoserver.wms.MapLayerInfo@anonymised.com extended-hash or sequence.
on line 1, column 21 in content.ftl. *in line:*
**<#assign longitud = features?size>*
Once we split the list with
*<#list features as feature*>
there's no problem to access to feature element.
Is there any change about features object in Geoserver 2.2? We have tried
to change freemarker-2.3.18.jar to other versions (2.3.19 and 2.3.13) but
we've got the same result.Any help will be appreciated, thanks in advance.
