Hi Simone:
After I read your message I attempted to add the filtering
capabilities to the imagemosaic module. I worked using geoserver
2.0-RC1 and geotools trunk. The filtering seems to work--I had to
modify the imagemosaic plugin a little, as well as GetMapResponse.java
in geoserver's WMS module.
Here is a sample request:
The result from the request can be seen here:
http://www.smoke-fire.us/misc/mosaic_filtered.png
Should I make a JIRA to see if the code can be included in svn?
Alex
On Thu, Aug 13, 2009 at 3:10 AM, Simone
Giannecchini<simone.giannecchini@anonymised.com> wrote:
Ciao Alex,
actually there is no such a capability in the currecnt version of the
imagemosaic, but it would be fairly easy to add it since internally
there is an index visitor that visit each feature in the JTS in memory
index, we could simply add the filter evaluation there.Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
Italyphone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928http://www.geo-solutions.it
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini-------------------------------------------------------
On Wed, Aug 12, 2009 at 10:08 PM, Alexander Petkov<greenkov@anonymised.com> wrote:
Hi:
Is it possible to filter an imagemosaic-configured coverage (or
imagemosaic-jdbc for that matter) with a filter or a cql_filter?
Similar to:
....&cql_filter=location='global_mosaic_9.png'The reason I am asking is that I have overlapping images in my mosaic,
and would like to filter out images that are from say a single date.
This is the request returning the full contents of the mosaic:Thanks,
Alex------------------------------------------------------------------------------
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-users mailing list
