On Wed, January 3, 2007 5:12 pm, Samuel Doyle wrote:
Thanks for the quick response.
I have deployed GeoServer as a war under GlassFish running under Linux.
Oh nice. I don't know for sure of anyone for sure with glassfish, would
definitely like to get it working so we can add it to the list of servers
we know work.
There are no errors in the deployment or indications in the logs. I am
able to see an xml generated output using the:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&versio
n=1.0.0&typename=tutorial as specified in the example. What do you mean by
"Will the GetMap ones generate images?"
Sorry, was a bit too terse. That's good to know the WFS works. What I'm
asking is, if you go to Demo -> Sample Requests there's a few requests
that do GetMap requests. I think one is called GetMap.url, and it does a
wms getMap request (which is what mapbuilder also does). If you select it
and use it, does it return a map of the US? Or errors?
Another thing to try is to use udig - http://udig.refractions.net - and
see if that will display the WMS. Basically we want to figure out if it's
a problem with GeoServer, or just with MapBuilder.
best regards,
Chris
Thanks, S.D.
Chris Holmes <cholmes@anonymised.com> wrote: What version of GeoServer are
you using? What operating system? Are you use a binary installed
version, or the war? Do you see any errors in the log? We've experienced
it before, but it's hard to diagnose the problem without more information.Also do the 'sample requests' work? Will the GetMap ones generate
images? If not what errors do they give?best regards,
Chris
On Wed, January 3, 2007 4:45 pm, Samuel Doyle wrote:
When following the demo for GeoServer to use the MapBuilder based
preview:
http://localhost:8080/geoserver/mapPreview.doAll the layer images come up as broken links. The application launches
but there is no image not just for my tutorial example but all the
others. Has anyone else encountered this?Thanks, S.D.
Join SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys - and earn
cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVD
EV!DSPAM:1003,459c24ec77652207481331!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:1003,459c24ec77652207481331!
Chris Holmes
The Open Planning Project
http://topp.openplans.org!DSPAM:1003,459c2b1386691804284693!
Chris Holmes
