[Geoserver-devel] GeoServer Winbuild failures
Given that I have access to a Windows development environment, I will see if I can fix some the test failures we are seeing (currently in the Core UI Module), without having to commit each fix and wait for the build box.
Torben
Thanks, that would be great.
On 4 December 2015 at 13:51, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741911&iu=/4140
Geoserver-devel mailing list
Jody Garnett
Pushed a couple of fixes. mvn clean install -Prelease builds fine on my windows box now.
On Fri, Dec 4, 2015 at 2:33 PM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
Torben
worked locally for me as well.
apparently the winbuild needs a kick, I will do that on Mon.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Sat, Dec 5, 2015 at 1:53 AM, Torben Barsballe
windows box now.
On Fri, Dec 4, 2015 at 2:33 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Torben
OSs.
OSs.
Torben,
Thanks for your help! It appears I made the same mistake a few times.
Regards
Niels
Torben
